Optoma EH415ST DLP 3500 Lumens Projector
Quicklinx: BG39WS00 Mfr#: EH415ST
Brightness: 3500ANSI lumens
Portability: Non-portable
£993.17 ex VAT
£1,191.80 inc VAT
The EH415ST is designed for delivering superior quality presentations in classrooms, small meeting rooms or training rooms. This full HD 1080p projector offers stunning image performance from a short distance. It also boasts a brightness rating of 3,500 ANSI lumens, which is ideal for use without dimming the lights.
The projector can be managed and monitored remotely with Crestron RoomView, Telnet, Extron IP Link, AMX and PJ-Link, which allow almost all aspects of the EH415ST to be controlled across a network.
The EH415ST's impressively long lamp life and energy-saving features both contribute to a low overall cost of ownership.
  • Short throw projection
    With a short-throw lens, this projector can produce large screen sizes from a short distance. This means you can get a 100 inch image, with the projector placed just over a meter away from the screen or wall.
  • High contrast
    Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • Full 3D
    Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144Hz rapid refresh rate provides ultra-smooth flicker free images. Full 3D
  • Integrated speaker
    The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers
  • Eco+
    Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption.
  • Energy saving
    Using the specially designed lamp modes, you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
  • Quick resume
    This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
  • Auto power off
    There may be instances when the projector is left running when not in use. To help save energy, the "Auto Power Off" feature automatically turns off the projector after a set period of time if it is not being used.
  • Eco AV mute
    Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption by up to 70%, further prolonging the life of your lamp.
  • Long lamp life
    Reduce the number of lamp change with lamp life of long hours using the education cycle.
  • Networking and control
    Featuring a wide range of options you can remotely control and monitor the projector.
  • Amazing colors
    For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multi-color processing technology.
Optoma EH415ST - DLP projector - short-throw - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Bundled Services
3 years Optoma Express Service
Microdisplay
DarkChip 3
Brightness
3500 lumens
Contrast Ratio
15000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens
Short-throw fixed lens
Bulb type
280 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 7000 hour(s) - Eco+ mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
290 Watt
28.6 cm x 26.6 cm x 12.4 cm
3.4 kg
3-year warranty
3D Capable
Bundled Services
Projector
Microdisplay
DarkChip 3
Brightness
3500 lumens
Contrast Ratio
15000:1
Image Size
150 cm - 386 cm
Projection Distance
0.66 m - 1.69 m
Throw Ratio
0.50:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 91 kHz
Bulb type
280 Watt
Bulb life cycle
OSD Languages
Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
BrilliantColor, PJlink, Crestron RoomView, 4:3 aspect ratio support, AMX Device Discovery, Eco+ technology
Lens
Lens Aperture
F/2.87
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
HDMI, component video, composite video, S-Video, RGB
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB (management)
Carrying case, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
Security Slot Type
Kensington security slot
RoHS
Nominal Voltage
290 Watt
Power Consumption Stand by
0.5 Watt
28.6 cm
26.6 cm
12.4 cm
3.4 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year
35 dB
Brand: Optoma
Price Range Ex VAT: 750 - 1000
