Optoma EH319UST 1920 x 1080 HDMI VGA 3D Projector
Quicklinx: BXT2WS00 Mfr#: EH319UST
Optoma's 1080p ultra short throw interactive projector, the EH319USTi, is perfect for businesses, schools and colleges. It is bright and uses the generation of TouchBeam finger-touch interactive technology, enabling several people to work simultaneously on the screen without using a pen. The throw ratio of 0.25:1 means that it can project a 100" image from just 55 cm away. And having the projector installed so close to the screen avoids any shadows being cast across the screen from the presenter.
It provides a complete package for engaging learning with many features, including two HDMI inputs, powered USB port, powerful 16 W built-in speaker, improved lamp life, compact chassis and a completely mounting system for a fast and simple set-up.
  • Ultra short throw
    With an ultra-short throw lens, you can project an impressive image greater than 100" from just 55 cm away. This allows you to place the projector closer to the wall, reducing shadows so you can present with ease; perfect for interactive applications.
  • TouchBeam interactive technology
    Optoma's TouchBeam finger-touch interactive technology enables several people to work simultaneously on the screen without using a pen. It is easy to draw, annotate, zoom and rotate images on the projected screen. You can even open documents or browse the web without touching your computer. Designed for businesses, schools and colleges, multiple touch points allow for a more natural and intuitive way of interacting with digital content.
  • High contrast
    Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • Full 3D
    Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144 Hz rapid refresh rate provides ultra-smooth flicker free images.
  • Integrated speaker
    The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers.
  • High contrast
  • Eco+
    Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption.
  • Energy saving
    Using the specially designed lamp modes, you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
  • Quick resume
    This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
  • Auto power off
    There may be instances when the projector is left running when not in use. To help save energy, the "auto power off" feature automatically turns off the projector after a set period of time if it is not being used.
  • Eco AV mute
    Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption by up to 70%, further prolonging the life of your lamp.
  • Remote mouse
    Keep your audience's attention focused on the right things using the simple, yet powerful remote with USB mouse control.
  • Amazing colors
    For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multi-color processing technology.
Optoma EH319USTi - DLP projector - ultra short-throw - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3500 ANSI lumens
Contrast Ratio
18000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens
Ultra short-throw lens
Bulb type
260 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
Video Input
RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
310 Watt
38.5 cm x 31 cm x 9.9 cm
4.85 kg
3D Capable
Built-in Devices
Speaker
Ethernet
Projector
Microdisplay
DarkChip 3
Brightness
3500 ANSI lumens
Contrast Ratio
18000:1
Image Size
203 cm - 254 cm
Projection Distance
0.45 m - 0.59 m
Throw Ratio
0.25:1
Uniformity
85 %
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 91.1 kHz
Bulb type
260 Watt
Bulb life cycle
OSD Languages
Danish, Hungarian, Czech, Slovenian, Thai, Chinese (traditional), Chinese (simplified), Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
BrilliantColor, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, PJlink, Crestron RoomView, 4:3 aspect ratio support, AMX Device Discovery, Auto Power Off, Eco+ technology, TouchBeam interactive technology
Lens
Lens Aperture
F/2.4
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone 3.5 mm , 1 x composite video input - RCA , 1 x microphone - mini-phone 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x USB (power only) - 4 pin USB Type A (power only) , 1 x 3D Sync out
2 Interactive Pens, wireless remote control, TouchBeam interactive module
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
310 Watt
Power Consumption Stand by
0.5 Watt
38.5 cm
31 cm
9.9 cm
4.85 kg
5 °C
0 - 85%
28 dB
