Optoma EH300 DLP 3500 Lumens Projector
Quicklinx: 96RHWS00 Mfr#: EH300
Utilizing the DLP technology, the EH300 delivers exceptional crystal-clear Full HD native resolution and immersive 3D visuals.
Producing a stunningly bright image with perfectly balanced vivid color, crystal clarity and exceptional light and shade detail only possible with a high contrast projector, the EH300 is perfect for projecting a broad range of applications including technical, advertising media and medical uses where detail matters.
Installed or on the move using the included carry bag, the versatile EH300 has a powerful on-board 16 W stereo speaker, HDMI connectivity and energy saving features including ECO mode and auto power off saving you both time and money for hassle-free, long-lasting projection.
Optoma EH300 - DLP projector - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Stereo speakers
Brightness
3500 lumens
Contrast Ratio
15000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-K, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC, PAL-L, SECAM I)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
297 Watt
32.4 cm x 23.4 cm x 9.7 cm
3.1 kg
3D Capable
Built-in Devices
Stereo speakers
Projector
Brightness
3500 lumens
Contrast Ratio
15000:1
Image Size
77 cm - 919 cm
Projection Distance
1.2 m - 10 m
Throw Ratio
1.5 - 1.8:1
Uniformity
80 %
Resolution
UXGA - WUXGA (1920 x 1200) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
85 Hz x 91 kHz
Bulb life cycle
Controls & Adjustments
Keystone correction
BrilliantColor, DynamicBlack technology, ProJect Green
Lens
Lens Aperture
F/2.55-2.87
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
8 Watt
Speakers
2 x right / left channel
2 x HDMI - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB - 4 pin USB Type B (management) , 1 x 3D Sync out
Carrying case, lens cover, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
297 Watt
Power Consumption Stand by
0.5 Watt
32.4 cm
23.4 cm
9.7 cm
3.1 kg
5 °C
0 - 85%
26 dB
