Project your presentations effortlessly any time on day with the bright DX349. Designed for meeting rooms and classrooms, this small projector boasts sRGB accurate true to life color reproduction, long lamp life and energy-saving features to provide you with a low overall cost of ownership.
High contrast
Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications. -
Full 3D
Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144 Hz rapid refresh rate provides ultra-smooth flicker free images. -
Integrated speaker
The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers -
Eco+
Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption. -
Energy saving
Using the specially designed lamp modes, you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance. -
Quick resume
This feature allows the projector to be instantly powered on again, if it is accidentally switched off. -
Auto power off
There may be instances when the projector is left running when not in use. To help save energy, the "Auto Power Off" feature automatically turns off the projector after a set period of time if it is not being used -
Eco AV mute
Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption by up to 70%, further prolonging the life of your lamp. -
Long lamp life
Reduce the number of lamp changes with lamp life of up to 10,000 hours using the Education Cycle. -
Amazing colors
For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multi-color processing technology.
- Optoma DX349 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker, 0.55-inch TFT LCD
- Microdisplay
- DarkChip 3
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 195 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 225 Watt
- 29.8 cm x 23 cm x 9.65 cm
- 2.17 kg
- DLP projector
- 3D Capable
- Built-in Devices
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 71 cm - 773 cm
- Projection Distance
- 1.2 m - 12 m
- Throw Ratio
- 1.95 - 2.16:1
- Uniformity
- 75 %
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 91.1 kHz
- Bulb type
- 195 Watt
- Bulb life cycle
- OSD Languages
- Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
- BrilliantColor, 16:9 aspect ratio support, Auto Power Off, Eco+ technology, ProJect Green
Lens
- Lens Aperture
- F/2.4-2.53
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- 1 x HDMI - 19 pin HDMI Type A , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x composite video input - RCA
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Mounting Kit
- Optional
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- RoHS
- Power Source
- AC
- Voltage Required
- 225 Watt
- Power Consumption Stand by
- 0.5 Watt
- 29.8 cm
- 23 cm
- 9.65 cm
- 2.17 kg
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 29 dB
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
