Simple to connect to with HDMI connectivity the DX346 is ideal for use in a meeting room or classroom. The bright 3000L with 13000:1 contrast allows you to project bright, crystal clear images with superb colors using DLP, BrilliantColor and Dynamic Eco+ technology.
The DX346 also provides you with energy and cost saving features with an incredible lamp life of up to 10000 hours. It also incorporates a built-in speaker, full 3D technology and wireless capabilities allowing you to present wirelessly from a PC or mobile device with ease.
Green solutions
Eco+ technology from Optoma increases the commitment to reducing the impact all make on the environment. -
Dynamic mode
Saving energy saves money! Dynamic mode reduces the power consumption to as little as 30%. This intelligent feature can more than double your expected lamp life, lowering the total cost of ownership and reducing maintenance. -
Eco AV mute
Stay in control of your presentation with the Eco AV mute feature. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also instantly reduces the power consumption to 25%, further prolonging the life of your lamp. -
Rapid off
It takes less than 10 seconds for the projector to power up and shutdown, saving both time and energy. -
Quick resume
Save time by not waiting for the projector to cool down before it can power up again. If the projector is accidentally turned off, this feature allows the projector to be instantly powered on again, if selected within a period of 100 seconds. -
Full 3D
Using the inherent speed of DLP technology, the Optoma DX346, full 3D projector can display true 3D content form any 3D display device, such as 3D Blu-ray, PS3, Xbox and Sky3D. -
Audio performance
Built-in 2 W speaker offers excellent audio support. The DX346 is easy to set up without the need for costly external speakers. -
Brightness where it matters
Room lighting can be unpredictable for the business traveler; you never know what to expect. The DX346 has a powerful lamp producing 3000 ANSI lumens, so you can be sure your presentation will be bright and clear. -
Cost saving - long lamp life
Reduce the number of lamp changes with lamp life of up to 10000 hours using the education cycle. -
Clear, focused images
Produce a stunning 15000:1 contrast ratio for pin sharp graphics and crystal clear text using the unique dynamic mode feature. Combined with DarkChip3 technology for texas instruments, dynamic mode automatically adjusts the lamp output, based on the brightness information of each frame; to create a stunning high contrast ratio. Bright scenes are crisp and clear, while dark scenes remain detailed with deep blacks which gives exceptional light and shade detail.
- Optoma DX346 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 13000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 225 Watt
- 31.46 cm x 22.26 cm x 10.17 cm
- 2.35 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 13000:1
- Image Size
- 70 cm - 762 cm
- Projection Distance
- 1.2 m - 12 m
- Throw Ratio
- 1.95 - 2.15:1
- Uniformity
- 80 %
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 91.1 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- OSD Languages
- Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
- BrilliantColor, DLP 3D Ready, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, Eco+ technology
Lens
- Lens Aperture
- F/2.41-2.55
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Output Power / Channel
- 2 Watt
- 1 x HDMI - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - mini-phone 3.5 mm , 1 x USB - mini-USB Type B (management) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Mounting Kit
- Optional
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- RoHS
- Voltage Required
- 225 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.46 cm
- 22.26 cm
- 10.17 cm
- 2.35 kg
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 29 dB
