Optoma DX346 DLP XGA 3000 Lumens Projector
Quicklinx: 9B3TWS00 Mfr#: DX346
Simple to connect to with HDMI connectivity the DX346 is ideal for use in a meeting room or classroom. The bright 3000L with 13000:1 contrast allows you to project bright, crystal clear images with superb colors using DLP, BrilliantColor and Dynamic Eco+ technology.
The DX346 also provides you with energy and cost saving features with an incredible lamp life of up to 10000 hours. It also incorporates a built-in speaker, full 3D technology and wireless capabilities allowing you to present wirelessly from a PC or mobile device with ease.
  • Green solutions
    Eco+ technology from Optoma increases the commitment to reducing the impact all make on the environment.
  • Dynamic mode
    Saving energy saves money! Dynamic mode reduces the power consumption to as little as 30%. This intelligent feature can more than double your expected lamp life, lowering the total cost of ownership and reducing maintenance.
  • Eco AV mute
    Stay in control of your presentation with the Eco AV mute feature. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also instantly reduces the power consumption to 25%, further prolonging the life of your lamp.
  • Rapid off
    It takes less than 10 seconds for the projector to power up and shutdown, saving both time and energy.
  • Quick resume
    Save time by not waiting for the projector to cool down before it can power up again. If the projector is accidentally turned off, this feature allows the projector to be instantly powered on again, if selected within a period of 100 seconds.
  • Full 3D
    Using the inherent speed of DLP technology, the Optoma DX346, full 3D projector can display true 3D content form any 3D display device, such as 3D Blu-ray, PS3, Xbox and Sky3D.
  • Audio performance
    Built-in 2 W speaker offers excellent audio support. The DX346 is easy to set up without the need for costly external speakers.
  • Brightness where it matters
    Room lighting can be unpredictable for the business traveler; you never know what to expect. The DX346 has a powerful lamp producing 3000 ANSI lumens, so you can be sure your presentation will be bright and clear.
  • Cost saving - long lamp life
    Reduce the number of lamp changes with lamp life of up to 10000 hours using the education cycle.
  • Clear, focused images
    Produce a stunning 15000:1 contrast ratio for pin sharp graphics and crystal clear text using the unique dynamic mode feature. Combined with DarkChip3 technology for texas instruments, dynamic mode automatically adjusts the lamp output, based on the brightness information of each frame; to create a stunning high contrast ratio. Bright scenes are crisp and clear, while dark scenes remain detailed with deep blacks which gives exceptional light and shade detail.
Optoma DX346 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3000 ANSI lumens
Contrast Ratio
13000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 480i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p
Speakers
Speaker(s) - integrated
225 Watt
31.46 cm x 22.26 cm x 10.17 cm
2.35 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
3000 ANSI lumens
Contrast Ratio
13000:1
Image Size
70 cm - 762 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.95 - 2.15:1
Uniformity
80 %
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
190 Watt
Bulb life cycle
OSD Languages
Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
BrilliantColor, DLP 3D Ready, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, Eco+ technology
Lens
Lens Aperture
F/2.41-2.55
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Output Power / Channel
2 Watt
1 x HDMI - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - mini-phone 3.5 mm , 1 x USB - mini-USB Type B (management) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
Wireless remote control
1 x VGA cable
Mounting Kit
Optional
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
RoHS
225 Watt
Power Consumption Stand by
0.5 Watt
31.46 cm
22.26 cm
10.17 cm
2.35 kg
5 °C
0 - 85%
29 dB
