Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144Hz rapid refresh rate provides ultra-smooth flicker free images.
High contrast
Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications. -
Full 3D
Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144Hz rapid refresh rate provides ultra-smooth flicker free images. -
Energy saving
Using the specially designed lamp modes, you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance. -
Auto power off
There may be instances when the projector is left running when not in use. To help save energy, the "Auto Power Off" feature automatically turns off the projector after a set period of time if it is not being used -
Eco AV mute
Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption by up to 70%, further prolonging the life of your lamp.
- Optoma DS346i - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 18000:1
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 225 Watt
- 31.5 cm x 22.4 cm x 10.2 cm
- 2.35 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 18000:1
- Image Size
- 58 cm - 762 cm
- Projection Distance
- 1 m - 12 m
- Throw Ratio
- 1.95 - 2.15:1
- Uniformity
- 80 %
- Resolution
- SVGA - SVGA (800 x 600)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 91.1 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- OSD Languages
- Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
- BrilliantColor, 16:9 aspect ratio support, AMX Device Discovery, Auto Power Off, Eco+ technology, ProJect Green
Lens
- Lens Aperture
- F/2.41-2.55
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x USB , 1 x USB - 4 pin USB Type A (power only) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x HDMI input - 19 pin HDMI Type A
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- RoHS
- Power Source
- AC
- Voltage Required
- 225 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.5 cm
- 22.4 cm
- 10.2 cm
- 2.35 kg
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 29 dB
