Optoma DH1017 DLP 4200 Lumens 3D Projector
Quicklinx: 9XC6WS00 Mfr#: DH1017
The Full HD DH1017 produces crystal clear, bright images, perfect for a broad range of applications including technical, advertising media and medical training where detail really matters. Full support for Crestron Roomview, Telnet, Extron IP Link, AMX dynamic device discovery and PJ-Link protocols, allow almost all aspects of the DH1017 to be controlled across a network, keeping you in control, wherever you are. The environmentally friendly DH1017 has energy saving features including less than 0.5 W standby mode and auto power off saving you both time and money.
  • Virtually maintenance free = lower cost of ownership
    DH1017 provides lower cost of ownership, longer life and improved reliability. The filter-free projector design does not require regular filter cleaning or filter replacement, saving you time and money.
  • Full HD
    Full HD (1920 x 1080) has more than twice the resolution of HD Ready (1280 x 720). DH1017 is compatible with HDTV broadcasts and high - definition media to project impressive full 1080p images and video in their original digital brilliance.
  • Amazing colors
    The DH1017 incorporates BrilliantColor technology to produce stunningly bright images with perfectly balanced life-like colors.
  • RS232 control
    The extensive RS232 command set makes it simple and easy to control the DH1017 with any control system.
  • Extensive connectivity
    This native 1080p projector accepts a wide variety of computer and video input signals.
  • Clear, focused images
    DarkChip3 technology from Texas instruments produces a stunning 10.000:1 contrast ratio for pin sharp graphics and crystal clear text. Crisper whites, ultra-rich blacks make images come alive and text easier to read.
  • 3D technology
    Using the inherent speed of DLP technology, Optoma Full 3D projectors can output video and images at an astonishing rate of 120 Hz, allowing you to show full screen, full color, and stereoscopic 3D. The 3D effect is generated by splitting this signal into two standard video streams, one for each eye.
  • Environmentally friendly
    The DH1017 incorporates energy saving features to conserve power and extend the lamp life.
Optoma DH1017 - DLP projector - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
4500 ANSI lumens
Contrast Ratio
10000:1
Resolution
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
310 Watt
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
370 Watt
32.6 cm x 25.4 cm x 10.4 cm
3.6 kg
3D Capable
Built-in Devices
Speaker
Projector
Brightness
4500 ANSI lumens
Contrast Ratio
10000:1
Image Size
72 cm - 867 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.59 - 1.91:1
Uniformity
85 %
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
144 Hz x 91 kHz
Bulb type
310 Watt
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic
sRGB colour profile, BrilliantColor, DynamicBlack technology, AMX Device Discovery, Auto Power Off, ProJect Green
Lens
Lens Aperture
F/2.5-2.76
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
3 Watt
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 2 x HDMI - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management)
Carrying case, lens cover, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
RoHS, WEEE
370 Watt
Power Consumption Stand by
0.5 Watt
32.6 cm
25.4 cm
10.4 cm
3.6 kg
5 °C
45 °C
0 - 85%
Sound Emission
28 dB
