Optoma DH1011i Full HD Projector 3200 Lumens and Built-in Speakers
Quicklinx: BNGWWS00 Mfr#: 95.79701GC1E
Utilizing the latest DLP technology, the DH1011 delivers exceptional crystal-clear Full HD native resolution and immersive 3D visuals. Producing a stunningly bright image with perfectly balanced vivid color, crystal clarity and exceptional light and shade detail only possible with a high contrast projector. The DH1011 is perfect for projecting a broad range of applications including technical, advertising media and medical uses where detail matters.
Installed or on the move using the included carry bag, the versatile DH1011 has a powerful on-board 16W stereo speaker, HDMI connectivity and energy saving features including ECO mode and auto power off saving you both time and money for hassle-free, long-lasting projection.
  • Lights on viewing
    The DH1011 produces fantastic images even when the lights are on with 3500 Lumens. Designed to be used in ambient light the high brightness DH1011 can be used without even dimming the lights.
  • Full HD 1080p
    Sharper more detailed projection with 1920 x 1080p pixels, perfect for watching Blu-ray movies without downscaling or compression.
  • Full 3D
    Using the inherent speed of DLP technology, The Optoma DH1011 Full 3D projector can display true 3D content form almost any 3D display device.
  • Dynamic black
    Dynamic black smoothly adjusts the lamp output automatically, based on the brightness information of each frame; to create a stunning 13,000:1 contrast ratio. Bright scenes are crisp and clear, while dark scenes remain detailed with deep blacks which gives exceptional light and shade detail.
  • Amazing colors
    The DH1011 incorporates BrilliantColor multi-color processing technology to bring stunning, vibrant color to your screen. You can even fine tune colors for ultimate precision.
  • Audio WOW - SRS WOW HD surround sound
    Embrace the WOW factor with SRS WOW HD surround sound audio processing to create a more natural audio experience with a deep, rich bass response. Easy to set up without the need for costly external speakers the DH1011 offers exceptional sound quality with powerful on-board 16W stereo audio.
Optoma DH1011i - DLP projector - portable - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3200 ANSI lumens
Contrast Ratio
18000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 4000 hour(s)
Video Input
RGB, component video
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
233 Watt
31.5 cm x 22.4 cm x 10.2 cm
2.55 kg
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3200 ANSI lumens
Contrast Ratio
18000:1
Image Size
106 cm - 775 cm
Projection Distance
1.5 m - 10 m
Throw Ratio
1.48 - 1.62:1
Uniformity
80 %
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
85 Hz x 91 kHz
Bulb type
190 Watt
Bulb life cycle
Up to 4000 hour(s)
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
BrilliantColor, AMX Device Discovery, Auto Power Off, Eco+ technology, MHL compliance
Lens
Focus Type
Manual
Lens Aperture
F/2.5-2.67
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, MHL
Video Modes
Speakers
Integrated
Output Power / Channel
10 Watt
1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x HDMI - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 (management) , 1 x USB , 1 x USB (power only) - 4 pin USB Type A
Wireless remote control
Mounting Kit
Optional
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
RoHS
Power Source
AC
233 Watt
Power Consumption Stand by
0.5 Watt
31.5 cm
22.4 cm
10.2 cm
2.55 kg
5 °C
0 - 85%
Sound Emission
29 dB
