Optoma DC450 Document Camera/Visualiser 720p/1080i 10x
Quicklinx: C61SWS00 Mfr#: DC450
  • SDHC Memory Card
£378.26 ex VAT
£453.91 inc VAT
When it comes to teaching people, it's often the detail that counts and more is always better. Being able to share your ideas and knowledge with a large audience can be difficult but a huge benefit.
With the Optoma DC450, you simply position items under the camera, connect it to a projector and show everything on the big screen live as it happens.
Information becomes clear and everyone shares your vision.
The DC450 features a 8-megapixel sensor, 80X total zoom (10X optical zoom / 8X digital zoom) and up to 30 frames-per-second video (at full resolution) for stunning image quality and performance allowing you to see detail often not visible to the human eye.
Take photos or video using the camera function and include them in future presentation - it's all so easy.
Create more engaging lesson content by easily capturing images, video and audio with the DC450 Document Camera.
You can even take a video of a science experiment with the document camera, save it on your PC/Laptop via USB or save to a SD card and use it in your next class and students can record their demonstrations during presentations for later review.
The DC450 is powerful, robust and full of useful features that will revolutionize any classroom lessons or meeting room presentations.
Optoma DC450 - digital document camera
Digital document camera
Audio
Yes: built-in speaker, built-in microphone
16 cm x 20 cm x 53 cm
1.65 kg
Wired
Camera
Optical Zoom
10 x
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/3.2" - 8 MP
Focus Adjustment
Automatic, manual
Lens Iris
F/2.8-3.5
USB 2.0, VGA, HDMI
1 - mini HDMI-HDMI cable - external , 1 - USB cable - external , 1 - VGA cable - external
Voltage
AC 120/230 V DC 5 V
Digital image freeze, SD-card slot, image mirror
3-year warranty
Audio Support
Wired
16 cm
20 cm
53 cm
1.65 kg
Camera
Max Digital Video Resolution
1920 x 1080
Digital Zoom
8
Frame Rate (max)
Still Image Capture Resolution
1280 x 720, 1600 x 1200, 1024 x 768, 1920 x 1080
Image Sensor
8 MP CMOS 1/3.2"
Lens Construction
Optical Zoom
10 x
Lens Iris
F/2.8-3.5
Focus Adjustment
Automatic, manual
Video
VGA, HDMI
Computer Interface
USB 2.0
Ports
VGA input , VGA , Mini-HDMI , Mini-HDMI input , USB - 4 pin USB Type B
Supported Memory Cards
SDHC Memory Card
Microscope adapters, remote control
1 x mini HDMI-HDMI cable - external , 1 x USB cable - external , 1 x VGA cable - external
Power Requirements
AC 120/230 V - DC 5 V
Power adapter - external
Microsoft Windows XP, Microsoft Windows 7
System Requirements Details
Windows XP/7 - Pentium 4 - 1.8 GHz - RAM 64 MB - HD 512 MB
Limited warranty - 3 years
Brand: Optoma
