Product
Optoma C340P 3100 ANSI Lumens XGA DLP Technology Projector
Quicklinx: C831WS00 Mfr#: 95.72G01GC2E.P
Project your presentations effortlessly any time on day with the bright X340. Designed for meeting rooms and classrooms this small projector boasts sRGB accurate true to life colour reproduction long lamp life and energy-saving features to provide you with a low overall cost of ownership.
This projector is easy to connect to with multiple inputs a built-in speaker and USB Power. Perfect for connecting HDMI dongles such as the Google Chrome-cast and the Optoma HDCast Pro (sold separately) or a laptop PC or Blu-ray player for clear projected images with sound. Portable and lightweight projector can be installed or taken on the move for off-site meetings with the optional carry bag (sold separately).
Bright and portable
  • Bright XGA projector – 3100 ANSI lumens.
  • Easy connectivity – HDMI VGA USB-A Power 2W speaker.
  • Low ownership costs – up to 10000 hours lamp life.
  • Lightweight and portable.
High contrast
Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks images come alive and text appears crisp and clear – ideal for business and education applications.
Full 3D
Optoma projectors can display true 3D content from almost any 3D source including 3D Blu-ray players 3D broadcasting and the latest generation games consoles. Support for 144Hz rapid refresh rate provides ultra-smooth flicker free images.
Integrated speaker
The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers.
Eco+
Eco+ technology brings together high contrast improved lamp life and energy saving features that are easy to use while reducing power consumption.
Energy saving
Using the specially designed lamp modes you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life while lowering the total cost of ownership and reducing maintenance.
Auto power off
There may be instances when the projector is left running when not in use. To help save energy the Auto Power Off feature automatically turns off the projector after a set period of time if it is not being used.
Eco AV mute
Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption by up to 70% further prolonging the life of your lamp.
Colour guarantee
Enjoy dazzling colours for years to come; guaranteed by Optoma for five years’ consistent performance.
Amazing colours
Give powerful presentations and educational lessons with stunning colours. Optoma projectors provide you with reliable colour performance suitable for any content and environment. From accurate sRGB colours for true life like images to vibrant punchy presentations. We have a display mode to specific meet your needs. Perfect for a range of graphic and video presentations.
Wireless
Stream Full 1080p 3D content to your projector wirelessly; eliminating the hassle and extra cost of installing long cables the WHD200 (sold separately) allows you to connect a Blu-ray™ player set-top box gaming console or AV receiver instantly.
USB power
Use the USB-Power to power an HDMI dongle such as Google Chromecast.
  • High contrast
    Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • Full 3D
    Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144Hz rapid refresh rate provides ultra-smooth flicker free images.
  • Integrated speaker
  • Eco+
    Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption.
  • Energy saving
    Using the specially designed lamp modes, you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
  • Quick resume
    This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
  • Auto power off
    There may be instances when the projector is left running when not in use. To help save energy, the "Auto Power Off" feature automatically turns off the projector after a set period of time if it is not being used
  • Eco AV mute
    Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption by up to 70%, further prolonging the life of your lamp.
  • Amazing colors
    Give powerful presentations and educational lessons with stunning colors. Optoma projectors provide you with reliable color performance suitable for any content and environment. From accurate sRGB colors for true life like images to vibrant punchy presentations.
  • USB power
    Use the USB-Power to power an HDMI dongle, such as Google Chromecast.
Optoma X340 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DMD Chip
Brightness
3100 ANSI lumens
Contrast Ratio
22000:1
Resolution
XGA (1024 x 768)
Colour Support
1.07 billion colours
Bulb type
195 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input
RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
225 Watt
29.8 cm x 23 cm x 9.65 cm
2.17 kg
DLP projector
3D Capable
Projector
Microdisplay
DMD Chip
Brightness
3100 ANSI lumens
Contrast Ratio
22000:1
Image Size
71 cm - 773 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.95 - 2.16:1
Uniformity
75 %
Resolution
XGA - XGA (1024 x 768)
Colour Support
Max Sync Rate (V x H)
120 Hz x 91.1 kHz
Bulb type
195 Watt
Bulb life cycle
Auto Power Off, Eco+ technology
Lens
Focus Type
Manual
Lens Aperture
F/2.4-2.53
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB (power only) - 4 pin USB Type A (power only)
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
Power Source
AC
Nominal Voltage
225 Watt
Power Consumption Stand by
0.5 Watt
29.8 cm
23 cm
9.65 cm
2.17 kg
5 °C
0 - 85%
29 dB
