Optoma 3600 Lumens WXGA Res DLP Technology Meeting Room Projector
Quicklinx: BPJ1WS00 Mfr#: W316ST
The Optoma W316ST is the perfect short throw projector solution for use in classrooms, training rooms, higher education, houses of worship and digital signage applications. With a powerful 3600 lumens bright image, a stunning contrast ratio and Dynamic Black technology, the W316ST delivers bright large-screen short throw presentations with superb image clarity, razor sharp detail and remarkable color accuracy. It provides complete connectivity for compatibility with analog and digital sources, including HDMI v1.4a with Full 3D capability, 2x VGA-in, VGA loop through, 2x audio-in, audio-out, RJ45, RS-232 control and advanced remote with laser and mouse control. Ultra-long lamp life and filter-free design minimize the cost of operation.
Optoma W316ST - DLP projector - short-throw - portable - 3D - white
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
White
Built-in Devices
Speaker
Bundled Services
3 years Optoma Express Service
Microdisplay
DarkChip 3
Brightness
3600 lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens
Short-throw fixed lens
Bulb type
210 Watt
Bulb life cycle
Up to 8000 hours - Eco+ mode , Up to 6500 hours - dynamic mode , Up to 6000 hours - economic mode , Up to 4000 hours - normal mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i
Speakers
Speaker(s) - integrated
280 Watt
31.5 cm x 22.4 cm x 10.2 cm
2.76 kg
3-year warranty
3D Capable
Built-in Devices
Speaker
Bundled Services
Enclosure Colour
White
Projector
Microdisplay
DarkChip 3
Brightness
3600 lumens
Contrast Ratio
20000:1
Image Size
112.5 cm - 765 cm
Projection Distance
0.49 m - 3.38 m
Throw Ratio
0.52:1
Uniformity
80 %
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 91.1 kHz
Bulb type
210 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
BrilliantColor, DLP 3D Ready, 16:9 aspect ratio support, DynamicBlack technology, 16:10 aspect ratio support, 4:3 aspect ratio support, AMX Device Discovery, Filter Free, Eco+ technology
Lens
Focus Type
Manual
Lens Aperture
F/2.8
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x HDMI input - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x USB - mini-USB Type B (management) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x microphone - mini-phone 3.5 mm
Lens cover, wireless remote control
Security Features
Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
280 Watt
Power Consumption Stand by
0.5 Watt
31.5 cm
22.4 cm
10.2 cm
2.76 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year
5 °C
0 - 85%
Sound Emission
29 dB
