NEC's UM351W is a 3500-lumen ultra-short throw projector that packs a multitude of features while delivering an extremely short throw distance for education and corporate applications. With its ability to be mounted to the wall directly above the screen on which it projects, this model helps eliminate the shadows and glare typically found with standard projection systems. The UM351W includes a powerful 20W speaker, closed captioning and RJ-45 for remote management over a network, and its input panel includes dual HDMI, VGA and a microphone input to amplify the presenter's voice.
- NEC UM351W - LCD projector - ultra short-throw - LAN
- LCD projector - 720p
- Built-in Devices
- Speaker
- Brightness
- 3500 ANSI lumens
- Contrast Ratio
- 4000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Lens
- Ultra short-throw lens
- Bulb type
- 255 Watt
- Bulb life cycle
- Up to 3800 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 344 Watt
- 37.8 cm x 42.8 cm x 11.2 cm
- 5.6 kg
- 3-year warranty
- Built-in Devices
- Speaker
Projector
- Brightness
- 3500 ANSI lumens
- Contrast Ratio
- 4000:1
- Image Size
- 147.3 cm - 279.4 cm
- Projection Distance
- 0.448 m - 0.854 m
- Throw Ratio
- 0.36:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
- 16:10
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 255 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Micro Lens Array (MLA) Technology, wall colour correction, PJlink, Crestron RoomView, DICOM Simulation Mode, Direct Power Off, Auto Power Off, built-in test pattern, auto power on, USB Viewer, Carbon Savings Meter, USB Display, Virtual Remote, Auto Eco Mode, High Altitude Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.8
- Zoom Factor
- 1.4x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -10 / +10
- Horizontal Keystone Correction
- -10 / +10
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 20 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
- Included Accessories
- Wireless remote control, NEC NP04WK1 wall mounting kit
- Cables Included
- 1 x VGA cable - 1.8 m
- Security Features
- Security lock slot (cable lock sold separately), security bar, keypad lock
- TUV GS, RoHS, GOST-R, ERP
- Power Source
- AC
- Nominal Voltage
- 344 Watt
- Power Consumption Stand by
- 0.4 Watt
- 37.8 cm
- 42.8 cm
- 11.2 cm
- 5.6 kg
- Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 38 dB
- Sound Emission (Economic Mode)
- 28 dB
