Optoma X304M XGA DLP 3000 Lumens Projector
Quicklinx: 93H4WS00 Mfr#: X304M
Brightness: 3000ANSI lumens
Portability: Portable
£418.41 ex VAT
£502.09 inc VAT
The Optoma X304M is the perfect projector for mobile professionals looking for a powerful, compact projector that is capable of delivering stunning presentations. Its 3000 ANSI lumens and 10,000:1 contrast ratio provide the brightness level you need to make your presentations stand out.
The Optoma X304M offers the level of connectivity necessary to satisfy your current and future needs, and its intuitive menu system makes it incredibly easy to operate. Designed for road warriors, the X304M is small in size, lightweight and strong in performance and reliability. Its DLP light engine ensures that your projector will deliver the same outstanding performance year after year.
Optoma X304M - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DarkChip 3
Brightness
3000 ANSI lumens
Contrast Ratio
10000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
SHP 220 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i
Speakers
Speaker(s) - integrated
280 Watt
22 cm x 17.8 cm x 7.09 cm
1.5 kg
DLP projector
3D Capable
Enclosure Colour
Projector
Microdisplay
DarkChip 3
Brightness
3000 ANSI lumens
Contrast Ratio
10000:1
Image Size
68 cm - 790 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.8 - 2.2:1
Uniformity
80 %
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.4 kHz
Bulb type
SHP 220 Watt
Bulb life cycle
Controls & Adjustments
Brightness, keystone correction, zoom
BrilliantColor, Side-by-Side, 16:9 aspect ratio support, Eco+ technology, ProJect Green
Lens
Focus Type
Manual
Lens Aperture
F/2.55-2.72
Zoom Type
Manual
Zoom Factor
1.15x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
1 x HDMI - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x audio line-out - mini-phone stereo 3.5 mm
Wireless remote control
1 x VGA cable
Mounting Kit
Optional
Security Features
Security lock slot (cable lock sold separately), keypad lock
Security Slot Type
Kensington security slot
Nominal Voltage
280 Watt
Power Consumption Stand by
0.5 Watt
22 cm
17.8 cm
7.09 cm
1.5 kg
Limited warranty - 2 years , Limited warranty - lamp - 1 year
5 °C
45 °C
0 - 85%
Sound Emission
33 dB
93H4 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
93H4 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.57
93H4 C2G 5m Select High Speed HDMI with Ethernet In Stock £21.91
93H4 C2G 10m Select High Speed HDMI with Ethernet In Stock £42.06
93H4 C2G 15m Select High Speed HDMI with Ethernet In Stock £56.98
93H4 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Brand: Optoma
Price Range Ex VAT: 300 - 500
