Onkyo HT-S7805 5.1.2 Dolby Atmos Home Cinema Package DTX WiF
Quicklinx: CKSKWS00 Mfr#: HT-S7805
Marketing description is not available.
  • Experience DTS: X and Dolby Atmos
    Make object-based Dolby Atmos and DTS: X surround sound reality in your living room. Sound flows naturally above and around you in three dimensions, putting you literally in the center of the action.
  • Quality speakers for object-based sound
    Joining two large OMF woofers and dome tweeters inside the front speakers are special drivers, that bounce discrete effects - such as birdcalls, rain, the sound of a helicopter - from the ceiling and into the audience. In fact, every element in object-based sound is mixed separately, so it's free to travel from speaker to speaker, anywhere around the room. Each solidly crafted speaker in this package reproduces advanced sound as its creators intended.
  • AccuEQ calibration featuring AccuReflex technology
    AccuEQ equalizes the surround-sound to suit the room acoustics for crisply focused sound, while AccuReflex aligns the phase of upfiring height speakers with sound coming from your other speakers. Delay is resolved, so that everything arrives at your ears at the same time. The result is cohesive reproduction of object-based soundtracks.
  • FireConnect multi-room audio
    A firmware update enables any audio source connected to the receiver - from vinyl to streaming audio - to be sent wirelessly via FireConnect to a speaker, placed anywhere in your home. Stable, fast, and easy to control with a mobile, it's the smart way to set audio free.
  • Dynamic audio amplification for thrilling sound
    Power your speakers like never before with Onkyo's unique dynamic audio amplification system. Music lives and breathes thanks to accurate, noise-free signal processing and hi-current power, that dynamically controls your speakers for authentic audio reproduction, filling you with emotion.
  • Play everything from vinyl to hi-res audio
    A phono input connects a turntable, so you can enjoy your record collection, and there is easy-to-use universal hi-res audio compatibility as well.
Onkyo HT-S7805 - home theater system - 5.1.2 channel
Home theater system
Components
Speaker system, AV network receiver
Enclosure Colour
Audio Channels
Surround Sound
Audio Specifications
Amplifier - 10 - 100000 Hz - 106 dB 0.08%
Decoders
Dolby TrueHD, DTS-HD Master Audio, Dolby Atmos, DTS:X
HDMI Switching
Surround Sound Effects
Theatre-Dimensional Virtual Surround
Sound Effects
DoubleBass
Surround System Class
5.1.2 channel
Source
Network, USB-host, Bluetooth
Audio Formats
WAV, WMA, AAC, MP3, FLAC, Apple Lossless, DSD
Radio System
AM/FM - 40 preset stations
Streaming Services
Deezer, Spotify, TuneIn, TIDAL
Ethernet, Fast Ethernet, Wi-Fi, Bluetooth
Speakers
2 x main channel speaker - external - 55 - 50000 Hz , 2 x height channel speaker - built-in main channel speaker - 80 - 20000 Hz , 1 x centre channel speaker - external - 65 - 50000 Hz , 2 x surround channel speaker - external - 80 - 20000 Hz , 1 x active subwoofer - external - 80 Watt - 27 - 150 Hz
Home theater system
Enclosure Colour
Audio System
Components
Audio Channels
Surround Sound
Decoders
3D Technology
Functions
Digital player, AV network receiver
Source
Audio Formats
Audio D/A Converter
32bit / 384kHz
High-Resolution Audio
Sound Effects
DoubleBass
Digital Sound Processor (DSP)
DSP Presets
Rock, Action, Sports, Role Playing Game (RPG)
5.1.2 channel
Amplifier - Response Bandwidth - 10 - 100000 Hz - SNR - 106 dB - THD - 0.08%
Input Impedance
47 kOhm
Input Sensitivity
200 mV
Amplifier Output details
160 Watt - 6 Ohm - at 1 kHz - THD 1% - 1 channels , 175 Watt - 6 Ohm - at 1 kHz - THD 10% - 1 channels
Bass Control
Treble Control
Digital Content Protection
HDCP 2.2
Bi-Amplifying, source direct, upgradeable firmware, dual-zone capability, Bluetooth Audio Streaming, Audio Return Channel (ARC), Apple AirPlay support, iPod/iPhone/iPad ready, x.v.Color, Deep Colour, Google Cast support, AccuEQ room acoustic calibration, Bluetooth 4.1 compatibility
Signal Processing Features
HDMI Switching
HDMI Pass-Through
Up to 4K
Speaker System
Speakers
2 x main channel speaker - 2-way - external - 55 - 50000 Hz - 6 Ohm - 84.5 dB - wired , 2 x height channel speaker - built-in main channel speaker - 80 - 20000 Hz - 6 Ohm - 81 dB - wired , 1 x centre channel speaker - 2-way - external - 65 - 50000 Hz - 6 Ohm - 86 dB - wired , 2 x surround channel speaker - external - 80 - 20000 Hz - 6 Ohm - 81 dB - wired , 1 x active subwoofer - external - 80 Watt - 27 - 150 Hz - wired
Driver Details
Main channel speaker: 1 x woofer driver - Onkyo Micro Fibre (OMF) , Main channel speaker: 1 x tweeter driver - balanced dome , Height channel speaker: 1 x full-range driver , Centre channel speaker: 2 x woofer driver , Centre channel speaker: 1 x tweeter driver - balanced dome , Surround channel speaker: 1 x full-range driver , Active subwoofer: 1 x subwoofer driver
Radio System
AM/FM - digital radio tuner
Preset Station Qty
40 preset stations
Network & Internet Multimedia
Streaming Services
Connectors
Headphones (phone stereo 6.3 mm) - front , HDMI input (19 pin HDMI Type A) - front , Audio line-in (mini-phone stereo 3.5 mm) - front , USB (4 PIN USB Type A) - rear , Network (RJ-45) - rear , 7 x HDMI input (19 pin HDMI Type A) - rear , 2 x HDMI output (19 pin HDMI Type A) - rear , 2 x composite video input (RCA) - rear , 2 x component video input (RCA x 3) - rear , 6 x audio line-in (RCA x 2) - rear , Phono input (RCA x 2) - rear , Audio line-out (multi zone) (RCA x 2) - rear , 2 x subwoofer output (RCA) - rear , SPDIF input (RCA) - rear , 2 x SPDIF input (TOS Link) - rear , AM antenna (click-fit x 2) - rear , FM antenna (IEC connector) - rear , 9 x speakers output (banana/spade x 2) - rear
AM antenna, remote control, FM antenna, auto calibration microphone, speaker cable kit
Dimensions (WxDxH) / Weight
AV network receiver: 43.5 cm x 37.8 cm x 17.35 cm / 10 kg , Speaker system: main/height channel speaker: 15.5 cm x 18.3 cm x 46.7 cm / 3.6 kg , Speaker system: centre channel speaker: 42 cm x 11.9 cm x 11.5 cm / 2.3 kg , Speaker system: surround channel speaker: 11.5 cm x 9.6 cm x 23 cm / 1 kg , Speaker system: active subwoofer: 23 cm x 41 cm x 42.5 cm / 7.7 kg
Width (Shipping)
77.2 cm
Depth (Shipping)
51.4 cm
Height (Shipping)
85.5 cm
Weight (Shipping)
36 kg
