Experience DTS: X and Dolby Atmos
Make object-based Dolby Atmos and DTS: X surround sound reality in your living room. Sound flows naturally above and around you in three dimensions, putting you literally in the center of the action. -
Quality speakers for object-based sound
Joining two large OMF woofers and dome tweeters inside the front speakers are special drivers, that bounce discrete effects - such as birdcalls, rain, the sound of a helicopter - from the ceiling and into the audience. In fact, every element in object-based sound is mixed separately, so it's free to travel from speaker to speaker, anywhere around the room. Each solidly crafted speaker in this package reproduces advanced sound as its creators intended. -
AccuEQ calibration featuring AccuReflex technology
AccuEQ equalizes the surround-sound to suit the room acoustics for crisply focused sound, while AccuReflex aligns the phase of upfiring height speakers with sound coming from your other speakers. Delay is resolved, so that everything arrives at your ears at the same time. The result is cohesive reproduction of object-based soundtracks. -
FireConnect multi-room audio
A firmware update enables any audio source connected to the receiver - from vinyl to streaming audio - to be sent wirelessly via FireConnect to a speaker, placed anywhere in your home. Stable, fast, and easy to control with a mobile, it's the smart way to set audio free. -
Dynamic audio amplification for thrilling sound
Power your speakers like never before with Onkyo's unique dynamic audio amplification system. Music lives and breathes thanks to accurate, noise-free signal processing and hi-current power, that dynamically controls your speakers for authentic audio reproduction, filling you with emotion. -
Play everything from vinyl to hi-res audio
A phono input connects a turntable, so you can enjoy your record collection, and there is easy-to-use universal hi-res audio compatibility as well.
- Onkyo HT-S7805 - home theater system - 5.1.2 channel
- Product Type
- Home theater system
- Components
- Speaker system, AV network receiver
- Enclosure Colour
- Black
- Audio Channels
- Surround Sound
- Audio Specifications
- Amplifier - 10 - 100000 Hz - 106 dB 0.08%
- Decoders
- Dolby TrueHD, DTS-HD Master Audio, Dolby Atmos, DTS:X
- HDMI Switching
- Surround Sound Effects
- Theatre-Dimensional Virtual Surround
- Sound Effects
- DoubleBass
- Surround System Class
- 5.1.2 channel
- Source
- Network, USB-host, Bluetooth
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, Apple Lossless, DSD
- Radio System
- AM/FM - 40 preset stations
- Streaming Services
- Deezer, Spotify, TuneIn, TIDAL
- Ethernet, Fast Ethernet, Wi-Fi, Bluetooth
- Speakers
- 2 x main channel speaker - external - 55 - 50000 Hz , 2 x height channel speaker - built-in main channel speaker - 80 - 20000 Hz , 1 x centre channel speaker - external - 65 - 50000 Hz , 2 x surround channel speaker - external - 80 - 20000 Hz , 1 x active subwoofer - external - 80 Watt - 27 - 150 Hz
- Product Type
- Enclosure Colour
- Black
Audio System
- Components
- Audio Channels
- Surround Sound
- Decoders
- 3D Technology
- Functions
- Digital player, AV network receiver
- Source
- Audio Formats
- Audio D/A Converter
- 32bit / 384kHz
- High-Resolution Audio
- Sound Effects
- DoubleBass
- Digital Sound Processor (DSP)
- DSP Presets
- Rock, Action, Sports, Role Playing Game (RPG)
- 5.1.2 channel
- Amplifier - Response Bandwidth - 10 - 100000 Hz - SNR - 106 dB - THD - 0.08%
- Input Impedance
- 47 kOhm
- Input Sensitivity
- 200 mV
- Amplifier Output details
- 160 Watt - 6 Ohm - at 1 kHz - THD 1% - 1 channels , 175 Watt - 6 Ohm - at 1 kHz - THD 10% - 1 channels
- Bass Control
- Treble Control
- Digital Content Protection
- HDCP 2.2
- Bi-Amplifying, source direct, upgradeable firmware, dual-zone capability, Bluetooth Audio Streaming, Audio Return Channel (ARC), Apple AirPlay support, iPod/iPhone/iPad ready, x.v.Color, Deep Colour, Google Cast support, AccuEQ room acoustic calibration, Bluetooth 4.1 compatibility
Signal Processing Features
- HDMI Switching
- HDMI Pass-Through
- Up to 4K
Speaker System
- Speakers
- 2 x main channel speaker - 2-way - external - 55 - 50000 Hz - 6 Ohm - 84.5 dB - wired , 2 x height channel speaker - built-in main channel speaker - 80 - 20000 Hz - 6 Ohm - 81 dB - wired , 1 x centre channel speaker - 2-way - external - 65 - 50000 Hz - 6 Ohm - 86 dB - wired , 2 x surround channel speaker - external - 80 - 20000 Hz - 6 Ohm - 81 dB - wired , 1 x active subwoofer - external - 80 Watt - 27 - 150 Hz - wired
- Driver Details
- Main channel speaker: 1 x woofer driver - Onkyo Micro Fibre (OMF) , Main channel speaker: 1 x tweeter driver - balanced dome , Height channel speaker: 1 x full-range driver , Centre channel speaker: 2 x woofer driver , Centre channel speaker: 1 x tweeter driver - balanced dome , Surround channel speaker: 1 x full-range driver , Active subwoofer: 1 x subwoofer driver
Radio System
- AM/FM - digital radio tuner
- Preset Station Qty
Network & Internet Multimedia
- Connectors
- Headphones (phone stereo 6.3 mm) - front , HDMI input (19 pin HDMI Type A) - front , Audio line-in (mini-phone stereo 3.5 mm) - front , USB (4 PIN USB Type A) - rear , Network (RJ-45) - rear , 7 x HDMI input (19 pin HDMI Type A) - rear , 2 x HDMI output (19 pin HDMI Type A) - rear , 2 x composite video input (RCA) - rear , 2 x component video input (RCA x 3) - rear , 6 x audio line-in (RCA x 2) - rear , Phono input (RCA x 2) - rear , Audio line-out (multi zone) (RCA x 2) - rear , 2 x subwoofer output (RCA) - rear , SPDIF input (RCA) - rear , 2 x SPDIF input (TOS Link) - rear , AM antenna (click-fit x 2) - rear , FM antenna (IEC connector) - rear , 9 x speakers output (banana/spade x 2) - rear
- Included Accessories
- AM antenna, remote control, FM antenna, auto calibration microphone, speaker cable kit
- Dimensions (WxDxH) / Weight
- AV network receiver: 43.5 cm x 37.8 cm x 17.35 cm / 10 kg , Speaker system: main/height channel speaker: 15.5 cm x 18.3 cm x 46.7 cm / 3.6 kg , Speaker system: centre channel speaker: 42 cm x 11.9 cm x 11.5 cm / 2.3 kg , Speaker system: surround channel speaker: 11.5 cm x 9.6 cm x 23 cm / 1 kg , Speaker system: active subwoofer: 23 cm x 41 cm x 42.5 cm / 7.7 kg
- Width (Shipping)
- 77.2 cm
- Depth (Shipping)
- 51.4 cm
- Height (Shipping)
- 85.5 cm
- Weight (Shipping)
- 36 kg
