Onkyo HT-S5805 5.1.2 Dolby Atmos Home Cinema Package
Quicklinx: CKSJWS00 Mfr#: HT-S5805
  • Dolby Digital
5.1.2-Channel Dolby Atmos® Home Cinema Package
Movie Night Will Change Forever
  • Supports Dolby Atmos® up to 5.1.2 Channels (Speakers Included)
  • 100 W per Channel
  • HDMI® 4 In / 1 Out (4K UltraHD / HDCP 2.2 / 4:4:4)
  • Pure Driving Power from Discrete Amp Technology
  • Bluetooth Wireless Audio Streaming
  • Simple Rear Panel Layout for Easy Connection
What an awesome way to experience game-changing Dolby Atmos® sound! Everything you need to create a face-melting entertainment system is right here in one simple package, starting with a 100 W/Ch A/V receiver that connects all your media players and sends video to the TV via a single HDMI® cable—from your old analog game consoles to the latest 4K/60 Hz video with 4:4:4 color space and 21:9 cinema aspect. Want full Smart TV capabilities? Plug a media streaming stick into the rearside STRM Box port and enjoy a wealth of audio and video streaming apps. Once you’ve connected the speaker system—which allows multidimensional Atmos soundtracks to flow above and around you—AccuEQ optimizes the sound to suit the unique shape of your room. We’ve also included Bluetooth technology so you can hear streamed audio with Onkyo’s legendary clarity and dynamism. Unleash tomorrow’s entertainment at home today!
Extraordinary Dolby Atmos®
Dolby Atmos transports you into an extraordinary surround sound experience with captivating multidimensional sound objects that fill your room and flow all around you. This 7.1-channel receiver powers a 5.1.2-channel Dolby Atmos speaker setup: 5.1 standard surround configuration plus two height channels inside the front speakers.
Top Quality Speaker System
Onkyo knows a thing or two about building great speakers, having almost 70 years’ experience in Hi-Fi. The included speaker package features precision drivers housed in solid cabinets—the front speakers also housing up-firing height drivers that unlock the magic of Dolby Atmos.
HDMI® 4 In / 1 Out for UltraHD
All HDMI terminals support the latest TV video displays, and HDCP 2.2 copy protection encoded in content from movie studios, broadcasters, and streaming services, for next-generation UltraHD.
True Power from Discrete Amplifiers
Discrete amps deliver high instantaneous current to increase speaker control for accurate and dynamic audio reproduction. This precise power is the cornerstone of Onkyo’s amplification philosophy.
Bluetooth Audio Streaming
Stream virtually any audio from your smartphone, tablet, or PC to your home cinema for clear and powerful sound.
AccuEQ Room Acoustic Calibration
AccuEQ measures and corrects speaker distances, output levels, crossover frequencies, and frequency response from one quick and easy listening position to ensure clear and balanced surround-sound.
HDMI Video Up-Conversion
Only one wire! Every video signal is converted and sent to your TV through one HDMI cable.
Ready for Streaming Media Devices
The handy STRM Box port supplies power to streaming media players. Keep up with your video subscription services and other programs streamed from the Internet.
Onkyo HT-S5805 - home theater system - 5.1.2 channel
Home theater system
Components
AV receiver, speaker system
Enclosure Colour
Audio Channels
Surround Sound
Audio Specifications
Amplifier - 10 - 100000 Hz - 100 dB 0.08%
Decoders
DTS-ES decoder, DTS 96/24, Dolby Digital, DTS decoder, DTS Express, Dolby Digital Plus, SBC decoder, DSD decoder, Dolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution, Dolby Atmos
Surround Sound Effects
Theatre-Dimensional Virtual Surround
Sound Effects
CinemaFILTER, Music Optimiser, Phase-Matching Bass Boost
Surround System Class
5.1.2 channel
Radio System
AM/FM - 40 preset stations
Speakers
2 x main channel speaker - external - 130 Watt - 55 - 50000 Hz , 1 x centre channel speaker - external - 130 Watt - 65 - 50000 Hz , 2 x surround channel speakers - external - 130 Watt - 80 - 20000 Hz , 1 x active subwoofer - external - 150 Watt - 27 - 150 Hz , 1 x height channel speaker - external - 130 Watt - 80 - 20000 Hz
AC 230V (50/60 Hz)
Home theater system
Enclosure Colour
Audio System
Components
Audio Channels
Surround Sound
Decoders
Functions
AV receiver
Audio D/A Converter
24bit / 192kHz
Sound Effects
Digital Sound Processor (DSP)
DSP Presets
Rock, Action, Sports, Role Playing Game (RPG)
5.1.2 channel
Amplifier - Response Bandwidth - 10 - 100000 Hz - SNR - 100 dB - THD - 0.08%
Input Impedance
47 kOhm
Input Sensitivity
200 mV
Amplifier Output details
100 Watt - 6 Ohm - at 1 kHz - THD 1.0% - 7 channels (surround)
Built-in clock
Timer, sleep timer
Bass Control
Treble Control
On-screen display, source direct, Wide Range Amplifier Technology (WRAT), Bluetooth Audio Streaming, Audio Return Channel (ARC), low-cut filter, AccuEQ room acoustic calibration
Speaker System
Speakers
2 x main channel speaker - 2-way - external - 130 Watt - 55 - 50000 Hz - 6 Ohm - wired , 1 x centre channel speaker - 2-way - external - 130 Watt - 65 - 50000 Hz - 6 Ohm - wired , 2 x surround channel speakers - external - 130 Watt - 80 - 20000 Hz - 6 Ohm - wired , 1 x active subwoofer - external - 150 Watt - 27 - 150 Hz - wired , 1 x height channel speaker - external - 130 Watt - 80 - 20000 Hz - 6 Ohm - wired
Driver Details
Main channel speaker: 1 x woofer driver - 5" , Main channel speaker: 1 x tweeter driver - 1" - balanced dome , Height channel speaker: 1 x full-range driver - 3.25" , Centre channel speaker: 2 x woofer driver - 3.25" , Centre channel speaker: 1 x tweeter driver - 1" - balanced dome , Surround channel speaker: 1 x full-range driver - 3.25" , Active subwoofer: 1 x subwoofer driver - 8"
Radio System
AM/FM - digital radio tuner
Preset Station Qty
40 preset stations
Supported RDS Functions
TP, PTY, PS, RT
Connectors
Headphones (phone stereo 6.3 mm) - front , Composite video/audio input (RCA x 3) - front , 4 x HDMI input (19 pin HDMI Type A) - rear , HDMI output (19 pin HDMI Type A) - rear , SPDIF input (RCA) - rear , 2 x SPDIF input (TOS Link) - rear , 6 x audio line-in (RCA x 2) - rear , 2 x component video input (RCA x 3) - rear , 2 x composite video input (RCA) - rear , Subwoofer output (RCA) - rear , 2 x front speakers output (banana/spade x 2) , 5 x speakers output (click-fit x 2) - rear , Remote control (mini-phone 3.5mm) - rear , FM antenna (IEC connector) - rear , AM antenna (click-fit x 2) - rear
AM antenna, FM antenna, 2 AA batteries, auto calibration microphone, universal remote control
AC 230V (50/60 Hz)
420 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Idle
55 Watt
Dimensions (WxDxH) / Weight
AV receiver: 43.5 cm x 32.8 cm x 16 cm / 8 kg , Speaker system: main channel speaker: 15.5 cm x 18.3 cm x 46.7 cm / 3.6 kg , Speaker system: centre channel speaker: 40.9 cm x 12.1 cm x 11.5 cm / 2.2 kg , Speaker system: surround channel speaker: 11.5 cm x 9.6 cm x 23 cm / 1 kg , Speaker system: active subwoofer: 23 cm x 41 cm x 42.5 cm / 7.7 kg
Width (Shipping)
77.2 cm
Depth (Shipping)
51.4 cm
Height (Shipping)
85.5 cm
Weight (Shipping)
34 kg
