The LS7200’s low-profile form contains a multi-driver array fed by a slim external amp connected via a single cable, reproducing Dolby Atmos® and DTS:X™ soundtracks with conviction. Effects move from channel to channel, immersing you in multidimensional sound, while music streamed wirelessly with DTS Play-Fi®*1, AirPlay®, or Wi-Fi® has substance that others can’t match. Players connect to the receiver’s four HDMI® inputs and wiring is concealed inside your entertainment unit for a near-invisible install. With a vast choice of entertainment within Onkyo Controller app (including multi-room audio), the LS7200 makes life better with sound tailored to you.
- Onkyo Envision Cinema LS7200 - home theater sound bar system - 5.1 channel
- Product Type
- Home theater sound bar system
- Components
- Speaker system, AV network receiver
- Enclosure Colour
- Black
- Audio Channels
- Surround Sound
- Audio Specifications
- Amplifier 80 dB
- Decoders
- Dolby Surround, DTS 96/24, Dolby Digital, DTS decoder, DTS Express, Dolby Digital Plus, DSD decoder, Dolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution, Dolby Atmos, DTS:X, DTS Neural:X
- Video Conversion/Scaling
- HDMI to HDMI scaling
- Surround Sound Effects
- Theatre-Dimensional Virtual Surround
- Sound Effects
- CinemaFILTER
- Surround System Class
- 5.1 channel
- Source
- Network, USB-host, Bluetooth
- Audio Formats
- WAV, WMA, AAC, AIFF, MP3, FLAC, Apple Lossless, LPCM, DSD
- Radio System
- FM
- Streaming Services
- Pandora, Deezer, Spotify, TuneIn, TIDAL
- Ethernet, Fast Ethernet, Wi-Fi, Bluetooth
- Speakers
- 1 x sound bar - external - 100 - 20000 Hz , 1 x subwoofer - external - 50 Watt - 30 - 200 Hz
- Power
- AC 120/230 V (50/60 Hz)
- Product Type
- Enclosure Colour
- Black
Audio System
- Components
- Audio Channels
- Surround Sound
- Decoders
- 3D Technology
- Functions
- Digital player, AV receiver, network audio player
- Source
- Audio Formats
- Sound Effects
- CinemaFILTER
- Digital Sound Processor (DSP)
- DSP Presets
- Enhanced, All Ch Stereo, TV Logic, Action, Sports, Mono, Full Mono, Multichannel
- 5.1 channel
- Amplifier SNR - 80 dB
- Input Impedance
- 47 kOhm
- Input Sensitivity
- 200 mV
- Amplifier Output details
- 50 Watt - 4 Ohm - at 1 kHz - THD 1% - 1 channels
- Bass Control
- Treble Control
- Digital Content Protection
- HDCP 2.2
- Multi-room audio output, Bluetooth Audio Streaming, Audio Return Channel (ARC), Apple AirPlay support, iPod/iPhone/iPad ready, smartphone remote controlled, x.v.Color, Deep Colour, AccuEQ room acoustic calibration, DTS Play-Fi Technology
Signal Processing Features
- HDMI Pass-Through
- Up to 4K
- Upscaling via HDMI
- Up to 4K
Speaker System
- Speakers
- 1 x sound bar - external - 100 - 20000 Hz - 4 Ohm - 78 dB/Watt - wired , 1 x subwoofer - external - 50 Watt - 30 - 200 Hz - wireless
- Driver Details
- Subwoofer: 1 x subwoofer driver - 6.3" , Sound bar: 6 x full-range driver - 2.76 x 1.57" , Sound bar: 2 x full-range driver - 2.28"
Radio System
- FM - digital radio tuner
- Tuner Frequency Range
- FM: 87.5 - 108 MHz
- FM Preset Station Qty
- 40 preset stations
- Supported RDS Functions
- PTY, RT
Network & Internet Multimedia
- Connectors
- 4 x HDMI input (19 pin HDMI Type A) - rear , HDMI output (19 pin HDMI Type A) - rear , Network (RJ-45) - rear , Digital audio input (optical) (TOS Link) - rear , Audio line-in (RCA x 2) - rear , USB (4 PIN USB Type A) - front , Headphones (mini-phone stereo 3.5 mm) - front
- Included Accessories
- Remote control, FM antenna, 2 AAA batteries, auto calibration microphone, speaker cable kit
- Voltage Required
- Dimensions (WxDxH) / Weight
- AV network receiver: 43.5 cm x 32.55 cm x 7 cm / 4 kg , Speaker system: sound bar: 95 cm x 8 cm x 5.5 cm / 2.3 kg , Speaker system: subwoofer: 26.1 cm x 26.9 cm x 33.8 cm / 6.2 kg
- Width (Shipping)
- 109.8 cm
- Depth (Shipping)
- 51.8 cm
- Height (Shipping)
- 35.4 cm
- Weight (Shipping)
- 18 kg
