Onkyo Envision Cinema LS7200 - Dolby Atmos DTS-X Wreless Soundbar
Quicklinx: CKSGWS00 Mfr#: LS-7200
  • Dolby Digital
The LS7200’s low-profile form contains a multi-driver array fed by a slim external amp connected via a single cable, reproducing Dolby Atmos® and DTS:X™ soundtracks with conviction. Effects move from channel to channel, immersing you in multidimensional sound, while music streamed wirelessly with DTS Play-Fi®*1, AirPlay®, or Wi-Fi® has substance that others can’t match. Players connect to the receiver’s four HDMI® inputs and wiring is concealed inside your entertainment unit for a near-invisible install. With a vast choice of entertainment within Onkyo Controller app (including multi-room audio), the LS7200 makes life better with sound tailored to you.
Onkyo Envision Cinema LS7200 - home theater sound bar system - 5.1 channel
Home theater sound bar system
Components
Speaker system, AV network receiver
Enclosure Colour
Audio Channels
Surround Sound
Audio Specifications
Amplifier 80 dB
Decoders
Dolby Surround, DTS 96/24, Dolby Digital, DTS decoder, DTS Express, Dolby Digital Plus, DSD decoder, Dolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution, Dolby Atmos, DTS:X, DTS Neural:X
Video Conversion/Scaling
HDMI to HDMI scaling
Surround Sound Effects
Theatre-Dimensional Virtual Surround
Sound Effects
CinemaFILTER
Surround System Class
5.1 channel
Source
Network, USB-host, Bluetooth
Audio Formats
WAV, WMA, AAC, AIFF, MP3, FLAC, Apple Lossless, LPCM, DSD
Radio System
FM
Streaming Services
Pandora, Deezer, Spotify, TuneIn, TIDAL
Ethernet, Fast Ethernet, Wi-Fi, Bluetooth
Speakers
1 x sound bar - external - 100 - 20000 Hz , 1 x subwoofer - external - 50 Watt - 30 - 200 Hz
Enclosure Colour
Audio System
Components
Audio Channels
Surround Sound
Decoders
3D Technology
Functions
Digital player, AV receiver, network audio player
Source
Audio Formats
Sound Effects
CinemaFILTER
Digital Sound Processor (DSP)
DSP Presets
Enhanced, All Ch Stereo, TV Logic, Action, Sports, Mono, Full Mono, Multichannel
5.1 channel
Amplifier SNR - 80 dB
Input Impedance
47 kOhm
Input Sensitivity
200 mV
Amplifier Output details
50 Watt - 4 Ohm - at 1 kHz - THD 1% - 1 channels
Bass Control
Treble Control
Digital Content Protection
HDCP 2.2
Multi-room audio output, Bluetooth Audio Streaming, Audio Return Channel (ARC), Apple AirPlay support, iPod/iPhone/iPad ready, smartphone remote controlled, x.v.Color, Deep Colour, AccuEQ room acoustic calibration, DTS Play-Fi Technology
Signal Processing Features
HDMI Pass-Through
Up to 4K
Upscaling via HDMI
Up to 4K
Speaker System
Speakers
1 x sound bar - external - 100 - 20000 Hz - 4 Ohm - 78 dB/Watt - wired , 1 x subwoofer - external - 50 Watt - 30 - 200 Hz - wireless
Driver Details
Subwoofer: 1 x subwoofer driver - 6.3" , Sound bar: 6 x full-range driver - 2.76 x 1.57" , Sound bar: 2 x full-range driver - 2.28"
Radio System
FM - digital radio tuner
Tuner Frequency Range
FM: 87.5 - 108 MHz
FM Preset Station Qty
40 preset stations
Supported RDS Functions
PTY, RT
Network & Internet Multimedia
Streaming Services
Connectors
4 x HDMI input (19 pin HDMI Type A) - rear , HDMI output (19 pin HDMI Type A) - rear , Network (RJ-45) - rear , Digital audio input (optical) (TOS Link) - rear , Audio line-in (RCA x 2) - rear , USB (4 PIN USB Type A) - front , Headphones (mini-phone stereo 3.5 mm) - front
Remote control, FM antenna, 2 AAA batteries, auto calibration microphone, speaker cable kit
Dimensions (WxDxH) / Weight
AV network receiver: 43.5 cm x 32.55 cm x 7 cm / 4 kg , Speaker system: sound bar: 95 cm x 8 cm x 5.5 cm / 2.3 kg , Speaker system: subwoofer: 26.1 cm x 26.9 cm x 33.8 cm / 6.2 kg
Width (Shipping)
109.8 cm
Depth (Shipping)
51.8 cm
Height (Shipping)
35.4 cm
Weight (Shipping)
18 kg
