The addition to the VN series, this affordable digital voice recorder has all the essentials for easily capturing meetings, lectures and more in clear quality.
Designed to capture every tone
The low-noise microphone features a large diameter and is omni-directional - ensuring it can capture sound from all directions while keeping background noise and breath sound to a minimum. This makes the voice recorder the perfect dictation device. -
Does the adjusting for you
To make listening to your recordings more comfortable, Intelligent Auto Mode automatically adjusts the recording level to match the volume of the sound source. When a speaker is talking very loudly, the recorder reduces the input level, and for soft voices the recorder increases the input level - to always provide an even level of volume. -
Made for beginners, just as perfect for advanced
With two different display modes, you can use your voice recorder even if you are a beginner. Simple Mode displays only essential information in large font and limits the menu options to frequently-used functions. For advanced users, full functionality of menu options is available in normal mode. -
The simplest way to save data
Save data easily and conveniently with the built-in USB connector. Simply slot it into your PC or Mac to transfer voice recordings from the device to an external hard disk drive. You can also use it like a USB stick to share documents.
- Olympus VN-741PC - voice recorder
- Product Type
- Voice recorder flash based
- 3.9 cm x 1.8 cm x 11.15 cm
- 77 g
- Playback Digital Standards
- MP3
- Sound Output Mode
- Stereo
- Output Power
- 250 mW
- Digital Recording Time
- 65 hours - MP3 recording - 128 kbps, 131 hours - MP3 recording - 64 kbps, 1040 hours - MP3 recording - 8 kbps
- Display
- LCD - 108 x 84 - monochrome - 1.61"
- Internal Memory
- 4 GB
- Speakers
- 1 x speaker - built-in - 250 mW
- Microphone
- Microphone - built-in - omni-directional
- Battery
- 2 x AAA type
- Product Type
- Voice recorder
- Digital Player Type
- Flash based
- USB Specification Version and Speeds
- USB 2.0
- Enclosure Material
- Plastic
- Audio Formats
- MP3
Audio System
- Internal Memory
- 4 GB
- File System Supported
- 4 GB
- Sound Output Mode
- Stereo
- Functions
- Digital player, digital voice recorder
- Alarm Wake-Up Modes
- Beep
- Hold button, on/off switch, built-in speaker, low-cut filter, built-in microphone, integrated fold-out stand
Amplifier
- Output Channel Qty
- 1 channels
- Output Power / Total
- 250 mW
Display
- LCD - monochrome
- Display Illumination
- Display Illumination Colour
- White
- Resolution
- 108 x 84
- Diagonal Size
- 1.61"
- Display Menu Language
- Danish, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Dutch, Chinese
Speaker System
- Speakers
- Driver Details
- Speaker: 1 - 0.79"
Digital Player (Recorder)
- Recording Time
- Data Storage Capability
- Up to 200 files / 5 folders
- External Hard Drive Function
- A-B repeat
Microphone
- Microphone Operation Mode
- Omni-directional
- Connector Type
- Microphone , Headphones , USB 2.0 (4 PIN USB Type A)
- Included Accessories
- USB cable
- Battery
- 2 x AAA type
- Included Qty
- 2
- Run Time (Up To)
- 110 hour(s)
- Battery Life Details
- Digital recording - up to 110 hour(s) , Digital playback - up to 90 hour(s)
- OS Required
- Apple MacOS X 10.5 - 10.9, Microsoft Windows Vista / 7 / 8 / 8.1
- 3.9 cm
- 1.8 cm
- 11.15 cm
- 77 g
