Olympus Tough TG-Tracker Action Camera - Black
Quicklinx: CQFTWS00 Mfr#: V104180BE000
Presenting an action cam that's tough enough to keep up with your adventures. The pocket-sized TG-Tracker records Ultra HD 4K video using advanced Olympus optics. Take it places you wouldn't dare take most cameras. Mountaintops. Winter slopes. Whitewater rafting or into the waves. Drop it, freeze it, submerge it, and it will just keep shooting - even 100 ft (30 m) underwater, no protective housing required. Handy extras like the LED headlight and the tilt-out monitor help you nail difficult shots. Use the built-in Action Track Sensors, GPS, and Wi-Fi to record and share every awesome moment. The TG-Tracker. It loves adventure as much as you do.
  • There's rugged and then there's TG-Tracker
    Sure, TG-Tracker looks rugged and compact, but there's more here than meets the eye. That's because Olympus Tough cameras are built strong so you can concentrate on getting great shots. TG-Tracker is waterproof to depths of 100 ft (30 m), crushproof up to 220 lbf (100 kgf), shockproof from 7 ft (2.1 m), freezeproof to 14°F (-10°C), and dustproof. Most other action cams need protective housings. That means more stuff to carry, clumsy camera operation, and a difficult time capturing sound. With TG-Tracker, no housing equals better overall performance.
  • Ultra HD 4K
    Record your adventures with so much vivid detail you'll feel like you're watching real life. That's the amazing resolution you get with Ultra HD 4K 30p video. Besides 4K, TG-Tracker gives you shooting options in Full HD 1080, HD 720, and standard definition, each with several frame rate options. Use the High Speed HD Video mode for slow-motion playback and the 4K Time Lapse Video mode to record captivating short video of long periods of time. The Loop Recording mode shoots continuously in 29 minute increments. Even still photos are covered with TG-Tracker's Still Shot mode.
  • Wide, bright, and super smart
    TG-Tracker's BSI CMOS sensor works with the TruePic VII for 4K Image Processor for video and stills rich with detail and vibrant color. Electronic 5-Axis Image Stabilization compensates for all types of movement, and the bright F2.0 aperture shoots clearly in low light and underwater. The 204° extreme-wide angle lens provides a dramatic, almost panoramic perspective.
  • Sense of adventure
    Sensor technology helps to track everything you see and do for an immersive experience that goes beyond video. There are five Action Track Sensors built into TG-Tracker. You'll find a GPS so you'll always know where you are. The e.Compass indicates direction. An accelerometer measures g-force. Keep an eye on your altitude or water depth with the barometric pressure sensor. The fifth sensor records ambient temperature. View real-time data on TG-Tracker's tilt-out LCD monitor. Activate Data Log Mode to record data without video for extended periods of time with limited battery use.
  • Shoot and share
    You're watching the sunrise from 12,000 feet above sea level. The climb was awesome and the video is spectacular. Get it to your friends, family, and social sites fast using TG-Tracker's built-in Wi-Fi. Quickly sync your smart device to your camera with the easy QR Code setup. Use the OI.Share app to remotely change settings and wirelessly share your shots. Use the OI.Track app to store still shots, video, and log data all on your smart device, then view videos and data simultaneously to relive the excitement. Your data is a record of your adventure. Have fun sharing your achievements.
Olympus Stylus Tough TG-Tracker - action camera
Action camera - 4K
Action Camera Type
Mountable
Memory Card Slot
SD card
Image Processor
TruePic VII
Sensors
Accelerometer, digital compass, barometer, thermometre, water sensor
Wireless Interface
Wi-Fi
Sensor Resolution
8.0 Megapixel
Max Video Resolution
3840 x 2160
Lens System
Wide-angle lens 1.58 mm f/2.0
Focus Adjustment
Focus free
Min Focus Distance
20 cm
Image Stabiliser
Electronic
Display
LCD display - 1.5"
Supported Battery
1 x Olympus Li-92B Li-ion rechargeable battery (included)
HDMI, USB 2.0
3.5 cm x 9.32 cm x 5.65 cm
180 g
Action camera - 4K
Enclosure Colour
Sensor Resolution
8.0 Megapixel
Optical Sensor Type
BSI-CMOS
Effective Sensor Resolution
8,000,000 pixels
Optical Sensor Size
1/2.3"
Frame Rate (Max Resolution)
30 fps
Image Processor
TruePic VII
Image Stabiliser
Electronic
Navigation
GPS/GLONASS receiver
Sensors
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
3840 x 2160
HDMI, USB 2.0, IEEE 802.11b/g/n
Exposure & White Balance
White Balance
Automatic, presets
White Balance Presets
Cloudy, sunlight, Underwater
Max Shutter Speed
1/24000 sec
Min Shutter Speed
1/2 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Wide-angle lens 1.58 f/2.0
Focal Length Equivalent to 35mm Camera
13.9mm
Focus Adjustment
Focus free
Min Focus Distance
20 cm
Max View Angle
204 degree(s)
Lens Construction
7 groups / 7 elements
Additional Features
Built-in Light
Additional Features
Built-in speaker, RGB primary colour filter, Time-Lapse recording, Loop recording
Action Camera Features
Camera Type
Mountable
Display
1.5" LCD display
Display Format
115,000 pixels
Display Form Factor
Folding
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 , HDMI output
Carrying strap, hand grip, AC power adaptor, USB cable, lens protect filter, mounting screw, mounting adapter, underwater lens cover
Protection
Waterproof, crushproof, freezeproof, shockproof, dust-resistant
Underwater Use
Underwater Depth
Up to 30 m
Battery Type
Olympus Li-92B Lithium Ion - manufacturer-specific
Details
Battery Life Details
Photo shooting - 480 shots , Video recording - 1.58 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card, microSDHC UHS-I Memory Card, microSDXC UHS-I Card
Memory Card Max Supported Size
128 GB
Video Capture
H.264 - 3840 x 2160 p - 30 fps , H.264 - 1920 x 1080 p - 60 fps , H.264 - 1920 x 1080 p - 30 fps , H.264 - 1280 x 720 p - 240 fps , H.264 - 1280 x 720 p - 120 fps , H.264 - 1280 x 720 p - 60 fps , H.264 - 1280 x 720 p - 30 fps , H.264 - 640 x 480 p - 240 fps , H.264 - 640 x 480 p - 120 fps , H.264 - 640 x 480 p - 60 fps , H.264 - 640 x 480 p - 30 fps
3.5 cm
9.32 cm
5.65 cm
180 g
-10 °C
Max Height of Shock Resistance
2.1 m
