The TG-870 is a Tough camera capable of capturing active scenes in the great outdoors. Its optical 5x zoom lens starting from an ultra-wide 21mm makes it easy to capture vast landscapes, and a 180° flip-up monitor helps shooting in narrow spots. It is also equipped with more Art Filters than the previous model, making it more enjoyable and convenient to use.
Tough capabilities & ultra-wide 21mm lens
The TG-870 is waterproof, dustproof, shockproof, and crushproof, letting you take photos anywhere, whether you are skiing on the slopes, on a severe trek, or snorkeling off of a reef. This model also features a wide 21mm lens that can be used to capture selfies against majestic landscapes. -
Advanced 180-degree flip-up monitor
By flipping the monitor up, you can view the subject from a variety of angles when shooting. -
Sportcam mode
The TG-870 features Sportcam mode for outdoor sports enthusiasts. When combined with the Sport Holder and face button, versatile movie recording is possible. -
Built-in Wi-Fi & GPS
This model is equipped with built-in Wi-Fi for easy photo sharing. It also possesses high-precision positioning functions such as the Assist GPS, useful in creating records of your outdoor activities and travels.
- Olympus Stylus Tough TG-870 - digital camera
- Product Type
- Digital camera - 1080p - compact
- Memory Card Slot
- SD card
- Image Processor
- TruePic VII
- Wireless Interface
- Wireless LAN
- Sensor Resolution
- 16.0 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 5x zoom - 3.74 - 18.7 mm - f/3.5-5.7
- Focus Adjustment
- Automatic
- Min Focus Distance
- 10 cm
- Digital Zoom
- 4x
- Image Stabiliser
- Optical (HYBRID O.I.S.)
- Camera Flash
- Built-in flash
- Display
- LCD display - 3"
- Supported Battery
- Olympus Li-50B Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Green
- 11.29 cm x 2.76 cm x 6.41 cm
- 221 g
- Product Type
- Enclosure Colour
- Green
- Sensor Resolution
- 16.0 Megapixel
- Optical Sensor Type
- BSI-CMOS
- Total Pixels
- 16,800,000 pixels
- Effective Sensor Resolution
- 16,000,000 pixels
- Optical Sensor Size
- 1/2.3"
- Frame Rate (Max Resolution)
- 60 fps
- ISO (Max)
- 6400
- Optical Zoom
- 5x
- Digital Zoom
- 4x
- Image Processor
- TruePic VII
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Navigation
- GPS receiver
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
- Auto Focus
- TTL contrast detection
- AE/AF Control
- Face-priority AF, Subject-tracking AF
- Face Detection
- Face-priority AF function
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
- Composite video/audio, HDMI, USB 2.0, Wireless LAN
- Computer Connectivity
- Mac, Windows
- Connectivity Features
- Remote control via mobile devices, remote live view, Wi-Fi & OI.Share
Exposure & White Balance
- Light Sensitivity
- ISO 800, ISO 125, ISO 400, ISO 200, ISO 1600, ISO 6400, ISO 3200, ISO auto
- Exposure Metering
- Multi-segment, spot
- Exposure Modes
- Programme, automatic
- Special Effects
- Vivid, fisheye, soft focus, natural, Muted, Water Colour, Diorama, Cross Process, Grainy Film, Light Tone, Pop Art, Pale & Light Colour, pin hole, Gentle Sepia, Dramatic Tone, Sparkle, Reflection, Fragmented, Key Line, Vintage
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Incandescent, fluorescent, cloudy, sunlight, Underwater
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 4 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
Lens System
- Focal Length Equivalent to 35mm Camera
- 21 - 105mm
- Focus Adjustment
- Automatic
- 10 cm
- Macro Focus Range
- 1cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 8 groups / 10 elements
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator, wireless off-camera control
- Effective Flash Range
- 0.12 m - 4 m: ISO 1600 (wide lens) , 0.1 m - 2.5 m: ISO 1600 (tele lens)
Additional Features
- Continuous Shooting Speed
- 2.5 frames per second, 60 frames per second (3MP), 20 frames per second (3MP), 7 frames per second for 7 frames
- Self-Timer Delay
- 2sec, 12sec
- Additional Features
- Audio recording, built-in speaker, cropping an image, resizing an image, in-camera red-eye fix, interval shooting mode, in-camera film editing, USB charging, Shadow Adjustment Technology, Intelligent AUTO (iAUTO), Eye-Fi Card Ready, Smart Panorama, Time-Lapse recording
Tripod Mount
- Connection Point
Display
- 3" LCD display
- Display Format
- 920,000 pixels
- Display Form Factor
- Folding
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB 2.0 , Composite video/audio output , HDMI output (19 pin micro HDMI Type D)
- Included Accessories
- AC power adaptor, USB cable, wrist strap
- Protection
- Waterproof, crushproof, freezeproof, shockproof, dust-resistant
- Underwater Use
- Underwater Depth
- Up to 15 m
- Battery Type
- Olympus Li-50B Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 300 shots , Video recording - 1.5 hours
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Memory Card Included
- No
- Video Capture
- H.264 - 1920 x 1080 p - 60 fps , H.264 - 1280 x 720 p - 60 fps , H.264 - 640 x 480 p - 60 fps , H.264 - 640 x 480 - 120 fps , H.264 - 854 x 480 - 120 fps , H.264 - 480 x 360 - 240 fps , H.264 - 640 x 360 - 240 fps
- 11.29 cm
- 2.76 cm
- 6.41 cm
- 221 g
- -10 °C
- Max Height of Shock Resistance
- 2.1 m
