Olympus PEN E-PL7 Compact Digital Camera & EZ Pancake Lens - Black
Quicklinx: C41FWS00 Mfr#: V205073BE001
The E-PL7 is a compact, interchangeable lens camera with a modern twist, built-in Wi-Fi and the upgraded OI.Share App let you control the camera remotely and post images instantly, while spectacular image quality, a selfie-centric touch screen interface and numerous creative tools make this the perfect choice for aspiring photographers.
Can such a small camera handle 15 different lenses? It can when it's the E-PL7. Build your system from an impressive assortment of M.Zuiko Micro Four Thirds fast primes, wide-angle and telephoto zooms, and macros, all with the unmatched digital-specific optics and premium build quality that set Olympus glass apart.
Genuine leather body jackets and lens covers. An add-on electronic viewfinder. A variety of external flashes. A compact underwater housing compatible with five M.Zuiko wide-angle and macro lenses. Add style and functionality to your E-PL7 with a wide array of premium accessories.
  • Sharp images ahead
    The same advanced core image processing technology - 16MP live MOS CMOS sensor, TruePic VII image processor and in-body three-axis image stabilization - found in Olympus' critically acclaimed OM-D E-M10 lives inside the E-PL7. Every nuance of your subjects will be captured at a level of detail that will astound you.
  • Fast and flexible
    Life moves fast - but the E-PL7 is faster. Its lightning-quick autofocus system facilitates high-speed sequential shooting - up to 8 frames per second. The 81-point AF grid covers the entire frame so you can zero in on any area. Improved AF tracking makes panning on a moving subject easier than ever, and focus peaking improves your accuracy in manual focus mode.
  • A smarter connection
    Turn your smartphone into a photographic accessory with the E-PL7. Its built-in Wi-Fi allows you to control the camera remotely, which is great for selfies, tripod shooting and - to the E-PL7 - video recording. The camera's unique QR code lets you instantly connect your smart device and camera using the newly improved OI.Share App.
  • License to create
    The E-PL7's array of fun and inventive in-camera creative tools includes 14 art filters, 7 art effects, 5 photo story layouts and built-in HDR. Photo & movie capture lets you shoot full-res stills and HD video simultaneously, while the old film effect adds scratches and dust marks to give your videos a vintage look.
Olympus PEN E-PL7 - digital camera M.Zuiko Digital 14-42mm lens
Digital camera - 1080p - mirrorless system
Lens Included
Memory Card Slot
SD card
Image Processor
TruePic VII
Wireless Interface
Wireless LAN
Sensor Resolution
16.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 3x zoom - 14 - 42 mm - f/3.5-5.6 ED EZ
Focus Adjustment
Automatic
Min Focus Distance
25 cm
Image Stabiliser
Optical (3-axis image sensor shift mechanism)
Camera Flash
Detachable flash
External Flash Name
Olympus FL-LM1
Display
LCD display - 3"
Supported Battery
Olympus BLS-50 Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
11.49 cm x 3.84 cm x 6.7 cm
357 g
Lens Included
Enclosure Colour
Sensor Resolution
16.1 Megapixel
Optical Sensor Type
Live MOS
Total Pixels
17,200,000 pixels
Effective Sensor Resolution
16,100,000 pixels
Optical Sensor Size
Four Thirds (17.3 x 13.0 mm)
ISO (Max)
25600
Native ISO
100-1600
Extended ISO (Max)
25600
Sensor Dust Reduction
Sensor Features
Supersonic Wave Filter (SWF)
Optical Zoom
3x
Image Processor
TruePic VII
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
HDR Mode
HDR post-processing
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
81
AE/AF Control
Face-priority AF, Subject-tracking AF, Touch Area AF, Eye detection AF
Face Detection
Eye Detect AF
Digital Video Format
AVI, MJPEG, H.264, MOV
Image Recording Format
JPEG, RAW, RAW + JPEG, MPO
1920 x 1080
Composite video/audio, HDMI, USB 2.0, Wireless LAN
Exposure & White Balance
Light Sensitivity
ISO 200-25600, ISO auto (200-25600)
Exposure Metering
Multi-segment, centre-weighted, spot, highlight spot, shadow spot
Exposure Metering Zones
324
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, macro, beach/snow, landscape-portrait, Children, fireworks, 3D image, night scene, panning, sports mode, sunset, candle, high key, night scene with portrait, low key, documents, nature macro, e-portrait, auto-panorama, fisheye converter, wide converter, macro converter, handheld starlight
Bracketing Modes
Art Filter bracketing, focus bracketing, ISO sensitivity bracketing
Special Effects
Soft focus, Water Colour, Diorama, Cross Process, partial colour, Grainy Film, Light Tone, Pop Art, Pale & Light Colour, pin hole, Gentle Sepia, Dramatic Tone, Key Line, Vintage
White Balance
Custom, automatic, presets
White Balance Presets
Sunlight, tungsten light, Flash, shade, overcast, Underwater, 2000K - 14000K
Shutter Type
Mechanical
Max Shutter Speed
1/4000 sec
Min Shutter Speed
60 sec
Exposure Compensation
±3 EV range, in 1, 1/2 or 1/3 EV steps
Auto Exposure Bracketing
7 steps in 1/3 or 2/3 EV steps
White Balance Bracketing
X-sync Speed
1/250sec, 1/4000 sec
Exposure Range
EV -2-20 - wide lens (ISO 100)
Lens System
Zoom lens - 3x zoom - 14 - 42 mm - f/3.5-5.6 ED EZ - zoom
Focal Length Equivalent to 35mm Camera
28 - 84mm
Focus Adjustment
Automatic
Min Focus Distance
25 cm
Max View Angle
75 degree(s)
Zoom Adjustment
Manual
Lens Construction
8 groups / 9 elements
Filter Size
40.5 mm
Lens Mounting Type
Micro Four Thirds
ED glass, aspherical lens
Camera Flash
Camera Flash
Detachable flash
Guide Number (m / ISO 100)
10
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator, flash +/- compensation, wireless off-camera control
External Flash Name
Olympus FL-LM1
Additional Features
Continuous Shooting Speed
8 frames per second, 3.7 frames per second
Self-Timer Delay
2sec, 12sec
Flash Terminal
Hot shoe
Additional Features
Audio recording, built-in speaker, auto power save, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, cropping an image, resizing an image, saturation control, in-camera red-eye fix, shadow point display, highlight point display, face detection, built-in help guide, Shadow Adjustment Technology, in-camera RAW processing, Full-time Live View, Intelligent AUTO (iAUTO), Eye-Fi Card Ready, Touch Shutter technology, FlashAir Card Ready
Display
3" LCD display
Display Format
1,037,000 pixels
Display Form Factor
Folding
Touch Screen
Display Features
Display brightness control, display colour control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction, sensitivity control
Connector Type
USB 2.0 , Composite video/audio output , HDMI output (19 pin micro HDMI Type D)
Software
Software
Drivers & Utilities, Olympus Viewer 2
Battery charger, dust cap, body cap, lens cap, shoulder strap, USB cable
Body Material
Metal
Battery Type
Olympus BLS-50 Lithium Ion
Details
Battery Life Details
Photo shooting - 350 shots (Live View mode)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
RAW 4608 x 3456 - 17 MB , JPEG 4608 x 3456 - 7.5 MB , JPEG 4608 x 3456 - 3.5 MB , JPEG 3200 x 2400 - 1.7 MB , JPEG 1280 x 960 - 0.4 MB
Video Capture
MOV - 1920 x 1080 - 30 fps - 24Mbps , MOV - 1920 x 1080 - 30 fps - 16Mbps , MOV - 1280 x 720 - 30 fps - 12Mbps , MOV - 1280 x 720 - 30 fps - 8Mbps , MJPEG - 1280 x 720 - 30 fps , MJPEG - 640 x 480 - 30 fps
11.49 cm
3.84 cm
6.7 cm
357 g
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
30 - 90%
Humidity Range Storage
10 - 90%
