Olympus NN-741PC 4GB Digital Voice Recorder with DNS Software -Black
Quicklinx: CB9DWS00 Mfr#: V415112BE000
The addition to the VN series, this affordable digital voice recorder has all the essentials for easily capturing meetings, lectures and more in clear quality.
  • Designed to capture every tone
    The low-noise microphone features a large diameter and is omni-directional - ensuring it can capture sound from all directions while keeping background noise and breath sound to a minimum. This makes the voice recorder the perfect dictation device.
  • Does the adjusting for you
    To make listening to your recordings more comfortable, Intelligent Auto Mode automatically adjusts the recording level to match the volume of the sound source. When a speaker is talking very loudly, the recorder reduces the input level, and for soft voices the recorder increases the input level - to always provide an even level of volume.
  • Made for beginners, just as perfect for advanced
    With two different display modes, you can use your voice recorder even if you are a beginner. Simple Mode displays only essential information in large font and limits the menu options to frequently-used functions. For advanced users, full functionality of menu options is available in normal mode.
  • The simplest way to save data
    Save data easily and conveniently with the built-in USB connector. Simply slot it into your PC or Mac to transfer voice recordings from the device to an external hard disk drive. You can also use it like a USB stick to share documents.
Olympus VN-741PC - voice recorder
Voice recorder flash based
3.9 cm x 1.8 cm x 11.15 cm
77 g
Playback Digital Standards
MP3
Sound Output Mode
Stereo
Output Power
250 mW
Digital Recording Time
65 hours - MP3 recording - 128 kbps, 131 hours - MP3 recording - 64 kbps, 1040 hours - MP3 recording - 8 kbps
Display
LCD - 108 x 84 - monochrome - 1.61"
Internal Memory
4 GB
Speakers
1 x speaker - built-in - 250 mW
Microphone
Microphone - built-in - omni-directional
2 x AAA type
Voice recorder
Digital Player Type
Flash based
USB Specification Version and Speeds
USB 2.0
Enclosure Material
Plastic
Audio Formats
MP3
Audio System
Internal Memory
4 GB
File System Supported
4 GB
Sound Output Mode
Stereo
Functions
Digital player, digital voice recorder
Alarm Wake-Up Modes
Beep
Hold button, on/off switch, built-in speaker, low-cut filter, built-in microphone, integrated fold-out stand
Amplifier
Output Channel Qty
1 channels
Output Power / Total
250 mW
Display
LCD - monochrome
Display Illumination
Display Illumination Colour
White
Resolution
108 x 84
Diagonal Size
1.61"
Display Menu Language
Danish, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Dutch, Chinese
Speaker System
Speakers
Driver Details
Speaker: 1 - 0.79"
Digital Player (Recorder)
Recording Time
Data Storage Capability
Up to 200 files / 5 folders
External Hard Drive Function
A-B repeat
Microphone
Microphone Operation Mode
Omni-directional
Connector Type
Microphone , Headphones , USB 2.0 (4 PIN USB Type A)
USB cable
Software
Dragon NaturallySpeaking
2 x AAA type
Included Qty
2
Run Time (Up To)
110 hour(s)
Battery Life Details
Digital recording - up to 110 hour(s) , Digital playback - up to 90 hour(s)
Apple MacOS X 10.5 - 10.9, Microsoft Windows Vista / 7 / 8 / 8.1
3.9 cm
1.8 cm
11.15 cm
77 g
