Olympus DS-3500 Digital Voice Recorder
Quicklinx: 8S1CWS00 Mfr#: V403110BE000
  • microSDHC
With its clear and simple operation concept, the DS-3500 ensures maximum efficiency and productivity. It has a 2" color TFT LCD with 60,000 colors and white LED backlight. Access to all main commands is cleverly positioned on the unit side to allow intuitive operation via push buttons. For conference recording it also provides additional audio codecs. With an external stereo microphone you can create stereo recordings in MP3 or PCM (WAV).
Olympus DS-3500 - voice recorder
Voice recorder flash based
Enclosure Colour
4.98 cm x 1.75 cm x 11.45 cm
107 g
Playback Digital Standards
WAV, MP3, DSSPro
Display
TFT - 176 x 220 - colour - 2"
Audio Specifications
Digital Player - response bandwidth: 50 - 21000 Hz
Supported Flash Memory Cards
SDHC, microSDHC
Speakers
1 x speaker - built-in
Microphone
Microphone
USB 2.0
Rechargeable - Lithium Ion
Voice recorder
Digital Player Type
Flash based
USB Specification Version and Speeds
USB 2.0
Enclosure Colour
Enclosure Material
Metal
Interface Supported
USB 2.0
Audio Formats
WAV, MP3, DSSPro
Audio System
SDHC, microSDHC
File System Supported
2 GB
Functions
Digital voice recorder
Digital Player - response time: 50 - 21000 Hz
Playback speed control, data encryption
Display
TFT - colour
Display Illumination
Display Illumination Colour
White
Colour Depth
65,000 colour
Resolution
176 x 220
Diagonal Size
2"
Display Menu Language
Danish, Czech, Slovak, English, German, French, Polish, Swedish, Russian, Spanish, Dutch
LED backlight
Speaker System
Speakers
Driver Details
Speaker: 1 - 1.1"
Microphone
Microphone
Connector Type
USB 2.0 , Microphone (mini-phone 3.5mm) , Headphones (mini-phone 3.5mm)
Carrying Case
Case - leather
USB cable, microSD Card (2GB)
1 x USB cable
Software
DSS Player Pro
Included Qty
1
Run Time (Up To)
21 hour(s)
4.98 cm
1.75 cm
11.45 cm
107 g
