With its clear and simple operation concept, the DS-3500 ensures maximum efficiency and productivity. It has a 2" color TFT LCD with 60,000 colors and white LED backlight. Access to all main commands is cleverly positioned on the unit side to allow intuitive operation via push buttons. For conference recording it also provides additional audio codecs. With an external stereo microphone you can create stereo recordings in MP3 or PCM (WAV).
- Olympus DS-3500 - voice recorder
- Product Type
- Voice recorder flash based
- Enclosure Colour
- Black
- 4.98 cm x 1.75 cm x 11.45 cm
- 107 g
- Playback Digital Standards
- WAV, MP3, DSSPro
- Display
- TFT - 176 x 220 - colour - 2"
- Audio Specifications
- Digital Player - response bandwidth: 50 - 21000 Hz
- Supported Flash Memory Cards
- SDHC, microSDHC
- Speakers
- 1 x speaker - built-in
- Microphone
- Microphone
- Interface
- USB 2.0
- Battery
- Rechargeable - Lithium Ion
- Product Type
- Voice recorder
- Digital Player Type
- Flash based
- USB Specification Version and Speeds
- USB 2.0
- Enclosure Colour
- Black
- Enclosure Material
- Metal
- Interface Supported
- USB 2.0
- Audio Formats
- WAV, MP3, DSSPro
Audio System
- SDHC, microSDHC
- File System Supported
- 2 GB
- Functions
- Digital voice recorder
- Digital Player - response time: 50 - 21000 Hz
- Playback speed control, data encryption
Display
- TFT - colour
- Display Illumination
- Display Illumination Colour
- White
- Colour Depth
- 65,000 colour
- Resolution
- 176 x 220
- Diagonal Size
- 2"
- Display Menu Language
- Danish, Czech, Slovak, English, German, French, Polish, Swedish, Russian, Spanish, Dutch
- LED backlight
Speaker System
- Speakers
- Driver Details
- Speaker: 1 - 1.1"
Microphone
- Microphone
- Connector Type
- USB 2.0 , Microphone (mini-phone 3.5mm) , Headphones (mini-phone 3.5mm)
- Carrying Case
- Case - leather
- Included Accessories
- USB cable, microSD Card (2GB)
- Cables Included
- 1 x USB cable
- Software
- DSS Player Pro
- Battery
- Included Qty
- 1
- Run Time (Up To)
- 21 hour(s)
- 4.98 cm
- 1.75 cm
- 11.45 cm
- 107 g
