Olympus Dictation & Transcription Starter Kit (DS-2600 + AS-2400)
Quicklinx: DR7XWS00 Mfr#: V741030BE010
Audio Formats: LPCM, DSSPro, MP3
£284.96 ex VAT
£341.95 inc VAT
Do you want to work faster and more efficiently? Using your voice instead of taking notes manually? Then make the switch: the DS-2600 is your personal digital solution. As an easy-to-use dictation device, it ensures greater efficiency in everyday work. Whether you're in a meeting, on your own or on the road, the DS-2600 supports you in your documentation and recording workflow.
  • Stay intuitive with the 4-position slide switch
    The slide switch enables easy and intuitive operation, allowing you to focus your thoughts on your dictation. Start, stop and edit your dictations easily via the robust slide switch without even looking at the device. This way, dictation is not only possible while sitting, but also on the move.
  • Save time: a whole range of editing options for easy text creation
    There is more to creating texts by speaking than just recording. The digital speech standard (DSS) allows for fast file editing (insert, overwrite, append, erase/cut).
  • High Quality Low-Noise Microphone
    The new DS series incorporates low noise omni-directional microphones and a shock absorber covers the microphone unit to minimize touch noises from your hand.
  • Including directional stereo recording
    During meetings, many people often talk in confusion and from different directions. No one is in a position to take notes so quickly and structured. The DS-2600 is especially suitable for capturing all your conferences. You can record your meetings with ease, but still in outstanding quality.
  • Easy dictation management with DSS Player Standard
    The DS-2600 comes with the DSS Player Standard (Mac & PC). This user-friendly software gives a complete overview of all your dictations to get your dictations managed easily. It also automatically imports your dictations from the voice recorder to your computer.
Olympus DS-2600 - voice recorder
Voice recorder flash based
Bundled with
Olympus AS-2400 Transcription Kit
Enclosure Colour
4.98 cm x 1.86 cm x 12 cm
116.5 g
Playback Digital Standards
MP3, LPCM, DSSPro
Display
LED - 240 x 320 2.4"
Audio Specifications
Digital Player - response bandwidth: 200 - 7000 Hz
Supported Flash Memory Cards
SDHC, SD Memory Card
Speakers
1 x speaker - built-in
Microphone
Two microphones - built-in
Rechargeable - Lithium Ion - 1350 mAh
Voice recorder
Digital Player Type
Flash based
Bundled with
Enclosure Colour
Audio Formats
MP3, LPCM, DSSPro
Audio System
File System Supported
2 GB
Functions
Digital voice recorder
Digital Player - response time: 200 - 7000 Hz
Voice activated, microphone sensitivity selection
Display
LED
Display Illumination
Display Illumination Colour
White
Resolution
240 x 320
Diagonal Size
2.4"
Display Menu Language
English, German, French, Italian, Russian, Spanish
Adjustable contrast, LED backlight
Speaker System
Speakers
Microphone
Connector Type
Microphone (mini-phone 3.5mm) , Headphones (mini-phone 3.5mm) , USB 2.0 , Docking station
1350 mAh
Recharge Time
2 hour(s)
4.98 cm
1.86 cm
12 cm
116.5 g
Audio Formats: LPCM
Audio Formats: DSSPro
Audio Formats: MP3
Brand: Olympus
