Olympus 8x40 DPS-I Binoculars inc Case & Strap
Quicklinx: CQG0WS00 Mfr#: N1240382
£50.92 ex VAT
£61.10 inc VAT
Featuring durable high-quality finish and extra wide field of view of 65°, the DPS I Series lets you discover the expansive nature around you with ease.
Olympus DPS I - binoculars 8 x 40
Binoculars
Dimensions
18.2 cm x 5.8 cm x 13.9 cm
0.71 kg
Magnification
8 x
Field of View
143 m / 1000 m
Objective Lens Diameter
40 mm
Eye Relief
12 mm
Prism System
Porro
Lens Coating
Coated
Max View Angle
6.5 degree(s)
Optical System
Binoculars
Length
13.9 cm
18.2 cm
5.8 cm
0.71 kg
Optical System
Magnification
8 x
40 mm
Prism System
Porro
Exit Pupil
5 mm
Eye Relief
12 mm
Eye Width Range
60-70 mm
Focus System
Center focus
Lens Coating
Coated
Lens Construction
4 groups / 6 elements
Min Focus Distance
4 m
Focus Adjustment
Manual
Max View Angle
6.5 degree(s)
Field of View
143 m / 1000 m
Dioptric Correction Range
± 1.0 dioptres
Lens System Features
Built-in UV filter, aspherical lens
Rubber coating
Lens cap, neck strap, carrying case
Brand: Olympus
