- Olympus - binoculars 8 x 21 RC II
- Product Type
- Binoculars
- Dimensions
- 10.6 cm x 3.8 cm x 8.8 cm
- 185 g
- Gold
- Magnification
- 8 x
- Field of View
- 110 m / 1000 m
- Objective Lens Diameter
- 21 mm
- Eye Relief
- 11.5 mm
- Prism System
- Roof
- Lens Coating
- Multicoated
- Max View Angle
- 6.3 degree(s)
- Carrying Case
- Case
- Optical System
- Binoculars
- Binoculars Series
- RC II
- Length
- 8.8 cm
- 10.6 cm
- 3.8 cm
- 185 g
- Enclosure Colour
- Gold
Optical System
- Magnification
- 8 x
- 21 mm
- Prism System
- Roof
- Exit Pupil
- 2.6 cm
- Eye Relief
- 11.5 mm
- Eye Width Range
- 37-72 mm
- Focus System
- Center focus
- Lens Coating
- Multicoated
- Lens Construction
- 3 groups / 5 elements
- Min Focus Distance
- 3 m
- Focus Adjustment
- Manual
- Max View Angle
- 6.3 degree(s)
- Relative Brightness
- 6.8
- Field of View
- 110 m / 1000 m
- Dioptric Correction Range
- ± 2.0 dioptres
- Foldable design
- Carrying Case
- Case
- Carrying Strap
- Neck strap
