Featuring durable high-quality finish and extra-wide field of view of 65° the DPS I let you discover the expansive nature around you with ease.
- Olympus DPS I - binoculars 8-16 x 40
- Product Type
- Binoculars
- Dimensions
- 18.2 cm x 5.8 cm x 15.2 cm
- 0.79 kg
- Special Functions
- Zoom
- Magnification
- 8-16 x
- Objective Lens Diameter
- 40 mm
- Eye Relief
- 12 mm
- Prism System
- Porro
- Lens Coating
- Coated
- Max View Angle
- 5 degree(s)
- Optical System
- Binoculars
- Length
- 15.2 cm
- 18.2 cm
- 5.8 cm
- 0.79 kg
Optical System
- Special Functions
- Zoom
- Magnification
- 8-16 x
- 40 mm
- Prism System
- Porro
- Eye Relief
- 12 mm
- Eye Width Range
- 60-70 mm
- Focus System
- Center focus
- Lens Coating
- Coated
- Lens Construction
- 4 groups / 6 elements
- Min Focus Distance
- 10 m
- Focus Adjustment
- Manual
- Max View Angle
- 5 degree(s)
- Magnification / View Angle
- 8 x / 5 degree(s) - field of view 87 m / 1000 m - relative brightness 25 , 16 x / 3.4 degree(s) - field of view 59 m / 1000 m - relative brightness 6.3
- Dioptric Correction Range
- ± 1.0 dioptres
- Rubber coating
- Included Accessories
- Lens cap, neck strap, carrying case
