Choosing a binocular can be a confusing business. There are so many factors involved, it can be difficult to figure out which model is right for you. But it's important to make the right choice. Whichever model you choose, the Olympus name assures you of the highest standards of optical quality, and a lifetime of viewing pleasure.
- Olympus DPS I - binoculars 10 x 50
- Product Type
- Binoculars
- Dimensions
- 19.1 cm x 6.3 cm x 17.8 cm
- 0.85 kg
- Magnification
- 10 x
- Field of View
- 114 m / 1000 m
- Objective Lens Diameter
- 50 mm
- Eye Relief
- 12 mm
- Prism System
- Porro
- Lens Coating
- Fully multicoated
- Max View Angle
- 6.5 degree(s)
- Optical System
- Binoculars
- Length
- 17.8 cm
- 19.1 cm
- 6.3 cm
- 0.85 kg
Optical System
- Magnification
- 10 x
- 50 mm
- Prism System
- Porro
- Exit Pupil
- 5 mm
- Eye Relief
- 12 mm
- Eye Width Range
- 60-70 mm
- Focus System
- Center focus
- Lens Coating
- Fully multicoated
- Lens Construction
- 3 groups / 5 elements
- Min Focus Distance
- 6 m
- Focus Adjustment
- Manual
- Max View Angle
- 6.5 degree(s)
- Relative Brightness
- 25
- Field of View
- 114 m / 1000 m
- Correction Angle
- ± 2°
- Lens System Features
- Built-in UV filter
- Rubber coating
