Product
Olympus 10x50 DPS-I Binoculars inc Case + Strap
Quicklinx: CQFVWS00 Mfr#: N1240482
10 in stock
£51.10 ex VAT
£61.32 inc VAT
Standard delivery Delivered within 3-5 working days
Choosing a binocular can be a confusing business. There are so many factors involved, it can be difficult to figure out which model is right for you. But it's important to make the right choice. Whichever model you choose, the Olympus name assures you of the highest standards of optical quality, and a lifetime of viewing pleasure.
Olympus DPS I - binoculars 10 x 50
Binoculars
Dimensions
19.1 cm x 6.3 cm x 17.8 cm
0.85 kg
Magnification
10 x
Field Of View
114 m / 1000 m
Objective Lens Diameter
50 mm
Eye Relief
12 mm
Prism System
Porro
Lens Coating
Fully multicoated
Max View Angle
6.5 degree(s)
Optical System
Binoculars
Length
17.8 cm
19.1 cm
6.3 cm
0.85 kg
Optical System
Magnification
10 x
50 mm
Prism System
Porro
Exit Pupil
5 mm
Eye Relief
12 mm
Eye Width Range
60-70 mm
Focus System
Center focus
Lens Coating
Fully multicoated
Lens Construction
3 groups / 5 elements
Min Focus Distance
6 m
Focus Adjustment
Manual
Max View Angle
6.5 degree(s)
Relative Brightness
25
Field Of View
114 m / 1000 m
Correction Angle
± 2°
Lens System Features
Built-in UV filter
Rubber coating
Brand: Olympus
Price Range Ex VAT: 50 - 100
