OKI Microline 5791eco Mono Dot-Matrix Printer
Quicklinx: 7MHTWS00 Mfr#: 01293201
The wide carriage ML5791 is ideal where fast printing, reliability, versatile paper handling and superior quality text is essential. Whether you are printing invoices, purchase orders, spreadsheets, picking lists, call log slips, tickets, receipts or multi-part documents, the ML5791 keeps transactions smooth and your customers happy.
The ML5791 has been developed with eco-friendly technology. With power consumption of just 1.5 w in sleep mode, your running costs and energy consumption are kept to a minimum, as well as reducing your carbon footprint.
More paper paths give you flexibility. The three tractor feeding paths handle multi-part forms and continuous paper from either the front, rear or bottom. The two friction feeding paths handle cut-sheets, cards and envelopes from either the front or top.
A selection of pull and push tractors allow permanent stationary loading, for use on demand and handle multi-part and continuous forms more efficiently.
OKI Microline 5791eco - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - B/W
10 kg
Max Media Size
Continuous paper 76.2 mm - 406.4 mm (width)
Min Media Size (Custom)
76.2 mm x 76.2 mm
Max Media Size (Custom)
406.4 mm x 558.8 mm
Print Speed
Up to 576 char/sec - high speed draft , Up to 480 char/sec - high speed draft , Up to 540 char/sec - draft , Up to 432 char/sec - draft , Up to 240 char/sec - letter , Up to 206 char/sec - letter , Up to 180 char/sec - letter , Up to 144 char/sec - letter , Up to 120 char/sec - letter , Up to 360 char/sec - draft , Up to 360 char/sec - draft , Up to 309 char/sec - draft
Max Resolution (B&W)
360 dpi
Parallel, USB
RAM Installed (Max)
128 KB
Language Simulation
EPSON ESC/P 2, IBM AGM, IBM PPR, EPSON LQ
Barcodes
Matrix 2 of 5, Industrial 2 of 5, Code 39, NW-7, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, OCR-A, OCR-B, Code 128B, Code 128C, Code 128A
Media Type
Envelopes, labels, plain paper, continuous forms, cards
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
3-year warranty with product registration
59.2 cm x 37.5 cm x 19.1 cm
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
Print Speed
Up to 576 char/sec - high speed draft - 12 cpi , Up to 480 char/sec - high speed draft - 10 cpi , Up to 540 char/sec - draft - 15 cpi , Up to 432 char/sec - draft - 12 cpi , Up to 240 char/sec - letter - 20 cpi , Up to 206 char/sec - letter - 17.1 cpi , Up to 180 char/sec - letter - 15 cpi , Up to 144 char/sec - letter - 12 cpi , Up to 120 char/sec - letter - 10 cpi , Up to 360 char/sec - draft - 10 cpi , Up to 360 char/sec - draft - 20 cpi , Up to 309 char/sec - draft - 17.1 cpi
Wired
Parallel, USB
360 dpi
Language Simulation
Fonts Included
1 x scalable , 1 x barcode
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Max Media Size
76.2 mm x 76.2 mm
406.4 mm x 558.8 mm
Media Sizes
Media Feeders
1 x manual - 1 sheet - continuous paper 76.2 mm - 406.4 mm (width)
Max Sheets in Multi-Part Form
6
1 x parallel , 1 x USB - 4 pin USB Type B
Consumables Included
1 x printhead - up to 400 million characters , 1 x ribbon - up to 13 million characters
MTBF
25,000 hour(s)
Power supply - internal
Frequency Required
50/60 Hz
52 Watt
Power Consumption Stand by / Sleep
1.5 Watt
Software Included
OKI LPR, OKI Status Monitor, OKI Network Set Up
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
Sound Emission (Operating)
57 dBA
Sound Emission (Quiet Mode)
52 dBA
59.2 cm
37.5 cm
19.1 cm
10 kg
