The ultra reliable ML5790eco dot matrix printer delivers fast, high quality printing of multi-part forms, truly versatile paper handling and impressively low energy consumption. Its high 576 characters per second (cps) print speed, fast throughput and ability to manage heavy medias make the ML5790eco perfect for high duty applications where presentation and print quality are essential. And with multiple emulations built-in, replacing old printers is simple and straightforward.
Ideal for printing customer facing documents such as receipts, invoices, dispatch notes and spreadsheets, on single or multipart paper, the ML5790eco will keep productivity levels high and document presentation professional.
- OKI Microline 5790eco - printer - monochrome - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - monochrome
- 7.5 kg
- Max Media Size
- Continuous paper 76.2 mm - 254 mm (width)
- Min Media Size (Custom)
- 76.2 mm x 76.2 mm
- Max Media Size (Custom)
- 254 mm x 558.8 mm
- Print Speed
- Up to 576 char/sec - high speed draft , Up to 480 char/sec - high speed draft , Up to 540 char/sec - draft , Up to 432 char/sec - draft , Up to 240 char/sec - letter , Up to 206 char/sec - letter , Up to 180 char/sec - letter , Up to 144 char/sec - letter , Up to 120 char/sec - letter , Up to 360 char/sec - draft , Up to 360 char/sec - draft , Up to 309 char/sec - draft
- Max Resolution (B&W)
- 360 dpi
- Interface
- Parallel, USB
- RAM Installed (Max)
- 128 KB
- Language Simulation
- EPSON ESC/P 2, IBM AGM, IBM PPR, EPSON LQ
- Barcodes
- Matrix 2 of 5, Industrial 2 of 5, Code 39, NW-7, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, OCR-A, OCR-B, Code 128B, Code 128C, Code 128A
- Media Type
- Envelopes, labels, plain paper, continuous forms, cards
- Power
- AC 230V
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- 3 years warranty with product registration
- 43.8 cm x 37.5 cm x 19.1 cm
- Printer Type
Printer
- Print Speed
- Up to 576 char/sec - high speed draft - 12 cpi , Up to 480 char/sec - high speed draft - 10 cpi , Up to 540 char/sec - draft - 15 cpi , Up to 432 char/sec - draft - 12 cpi , Up to 240 char/sec - letter - 20 cpi , Up to 206 char/sec - letter - 17.1 cpi , Up to 180 char/sec - letter - 15 cpi , Up to 144 char/sec - letter - 12 cpi , Up to 120 char/sec - letter - 10 cpi , Up to 360 char/sec - draft - 10 cpi , Up to 360 char/sec - draft - 20 cpi , Up to 309 char/sec - draft - 17.1 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 360 dpi
- Fonts Included
- 1 x scalable , 1 x barcode
- Barcodes
RAM
- 128 KB
Media Handling
- Media Type
- Max Media Size
- 76.2 mm x 76.2 mm
- 254 mm x 558.8 mm
- Media Sizes
- Media Feeders
- 1 x manual - 1 sheet - continuous paper 76.2 mm - 254 mm (width)
- Max Sheets in Multi-Part Form
- 6
- Connections
- 1 x parallel , 1 x USB - 4 pin USB Type B
- Consumables Included
- 1 x printhead - up to 400 million characters , 1 x ribbon - up to 8 million characters
- MTBF
- 25,000 hour(s)
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 52 Watt
- Power Consumption Stand by / Sleep
- 1.5 Watt
- Software Included
- OKI LPR, OKI Status Monitor, OKI Network Set Up
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- Sound Emission (Operating)
- 57 dBA
- Sound Emission (Quiet Mode)
- 52 dBA
- 43.8 cm
- 37.5 cm
- 19.1 cm
- 7.5 kg
