The Microline 320 wide carriage printers are suited to high speed, high volume data and word processing applications, where speed is more important than letter quality. Reliability, ease of use and fast throughput make them ideal for customer service points in wholesale, retail and service environments: multi-part forms, labels, listings, customer service points, accounts and spreadsheets.
- OKI Microline 320 - printer - B/W - dot-matrix
- Printer Type
- Personal printer - dot-matrix - 9 pin - B/W
- Form Factor
- Desktop
- 7.8 kg
- Max Media Size
- B4 (250 x 353 mm)
- Max Media Size (Custom)
- 254 mm
- Print Speed
- Up to 360 char/sec - draft , Up to 62.5 char/sec - near letter
- Max Resolution (B&W)
- 216 x 240 dpi
- Interface
- Parallel
- RAM Installed (Max)
- 28 KB (28 KB) integrated
- Language Simulation
- Okidata Microline
- Media Type
- Labels, plain paper, continuous forms
- Power
- AC 230V
- Enclosure Colour
- White
- 3-year warranty with product registration
- 39.8 cm x 34.5 cm x 11.6 cm
- Printer Type
- Personal printer - dot-matrix - 9 pin - monochrome
- Form Factor
- Desktop
- Enclosure Colour
- White
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- Parallel
- 216 x 240 dpi
- PostScript Support
- Not available
- Okidata Microline
- Fonts Included
- 2 x bitmapped
RAM
- 28 KB / 28 KB (max)
- Technology / Form Factor
- Integrated
Media Handling
- Media Path Type
- Straight
- Media Type
- Max Media Size
- B4 (250 x 353 mm)
- 254 mm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), B4 (250 x 353 mm)
- Envelope Sizes
- US No 6 (92 x 165 mm)
- Max Sheets in Multi-Part Form
- 5
Duty Cycle
- Cartridge / Printhead Duty Cycle
- 200 million characters
- Cartridge / Printhead Included Qty
- 1
- Connections
- 1 x parallel - 36 PIN Centronics
- Power Device
- Power supply - integrated
- Voltage Required
- AC 230V ± 10%
- Frequency Required
- 50/60 Hz
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- Sound Emission
- 57 dBA
- 39.8 cm
- 34.5 cm
- 11.6 cm
- 7.8 kg
