Your basket is empty
OKI Microline 280 Elite DC Mono Dot-Matrix Printer
Quicklinx: 7QP8WS00 Mfr#: 01138610
The Microline 280 Elite is Oki's smallest dot matrix printer offering perfect print quality at very low cost. High reliability and very compact dimensions make it especially suited for front/back office applications and industrial environments (multipart forms, logs, labels etc.). The Microline 280 Elite is ideal for integration into measurement and control systems. The DC version is intended for mobile or remote use.
OKI Microline 280 Elite DC - printer - monochrome - dot-matrix
Printer Type
Personal printer - dot-matrix - 9 pin - monochrome
4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
254 mm
Print Speed
Up to 300 char/sec - max speed , Up to 240 char/sec - draft , Up to 50 char/sec - near letter
Max Resolution (B&W)
240 x 216 dpi
Parallel
RAM Installed (Max)
128 KB
Language Simulation
EPSON FX, Okidata Microline
Barcodes
Code 39, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type
Plain paper, continuous forms
DC 9.6 - 31.2 V
3 years warranty with product registration (Germany - 3 years (on-site) with product registration)
36 cm x 27.5 cm x 8 cm
Printer Type
Printer
Print Speed
Up to 300 char/sec - max speed - 12 cpi , Up to 240 char/sec - draft , Up to 50 char/sec - near letter
Wired
Parallel
240 x 216 dpi
Language Simulation
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
254 mm
Media Sizes
Fanfold (25.4 cm)
Media Weight
35 g/m² - 90 g/m²
Media Feeders
1 x manual - 1 sheet
Max Sheets in Multi-Part Form
4
1 x parallel - 36 PIN Centronics
Consumables Included
1 x printhead - up to 200 million characters , 1 x ribbon - up to 3 million characters
MTBF
20,000 hour(s)
Power supply
DC 9.6 - 31.2 V
Limited warranty - 3 years - carry-in
Sound Emission (Operating)
51 dBA
36 cm
27.5 cm
8 cm
4 kg
7QP8 OKI ML - 182 / 192 / 280 / 320 / 3320 Black In Stock £6.76
