These compact and robust dot matrix printers not only produce great resolution output but also come with proven, class leading reliability. With USB fitted as standard, businesses can now enjoy greater flexibility and seamless connectivity, without having to compromise on price or performance.
- OKI Microline 1190 - printer - B/W - dot-matrix
- Printer Type
- Personal printer - dot-matrix - 24 pin - B/W
- 4.2 kg
- Max Media Size
- Continuous paper 76.2 mm - 245 mm (width)
- Max Media Size (Custom)
- 245 mm
- Print Speed
- Up to 333 char/sec - max speed , Up to 250 char/sec - normal , Up to 83 char/sec - letter
- Max Resolution (B&W)
- 360 dpi
- Interface
- Parallel, USB, serial
- RAM Installed (Max)
- 64 KB
- Language Simulation
- IBM AGM, IBM PPR, EPSON LQ
- Barcodes
- OCR-A, OCR-B
- Media Type
- Plain paper, continuous forms
- 3-year warranty with product registration
- 34.9 cm x 23.2 cm x 15 cm
- Printer Type
- Personal printer - dot-matrix - 24 pin - monochrome
Printer
- Print Speed
- Up to 333 char/sec - max speed - 10 cpi , Up to 250 char/sec - normal - 10 cpi , Up to 83 char/sec - letter - 10 cpi
- Connectivity Technology
- Wired
- Interface
- 360 dpi
- Fonts Included
- 1 x barcode , 1 x scalable
- Barcodes
- OCR-A, OCR-B
RAM
- 64 KB
Media Handling
- Media Type
- Max Media Size
- 245 mm
- Media Sizes
- Media Feeders
- 1 x manual - 1 sheet - continuous paper 76.2 mm - 245 mm (width)
- Max Sheets in Multi-Part Form
- 5
- Connections
- 1 x parallel - 36 PIN Centronics , 1 x RS-232 - 25 pin D-Sub (DB-25) , 1 x USB - 4 pin USB Type B
- Consumables Included
- 1 x ribbon (black) - up to 4 million characters , 1 x printhead - up to 400 million dots
- MTBF
- 10,000 hour(s)
- Power Device
- Power adapter - internal
- Frequency Required
- 50/60 Hz
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- Sound Emission (Operating)
- 51 dBA
- 34.9 cm
- 23.2 cm
- 15 cm
- 4.2 kg
