Designed to perform, with high print speeds and efficient use of consumables, the MC873 color A3 MFP is a 4-in-1 multifunction printer that is ideal for the more demanding workgroup. This smart MFP incorporates automatic double sided copying, printing, scanning and faxing to make life easy and optimizes its speed and power usage to make every saving possible. With print speeds of up to 35ppm, just 9.5 seconds to first print, and 10 seconds to first copy, it offers secure and intuitive functionality that enables easy and efficient integration with as well as management of any document workflow. The MC873 combines the reliability of OKI's award winning digital LED print technology with the added functionality and performance of more costly and complex copier-based devices, ensuring outstanding print and copy quality as well as comprehensive scan and document management.
Print smart to save time and money
Management and printing of your documents is so much simpler with tools that give you the ability to create a full range of documents in-house. The MC873 can accommodate a wide range of paper weights (up to 256gsm) and sizes (from A6 to 1.3m banner) with a maximum paper capacity up to 2,005 sheets for added flexibility, while intuitive document management technology is built into the device. -
Reduce your total cost of ownership
The MC873 offers considerable cost savings throughout its life span, combining exceptional energy efficiency with high capacity toner cartridges and many paper saving functions. Additionally this smart MFP combines 4 devices into one offering the capability of a printer, fax, copier, and scanner at no extra cost. -
High definition scanning for improved document workflow
Providing sharp, fast, and accurate LED scanning, the MC873 enables you to digitise your documents clearly and easily - and you can scan directly to email, USB, network folder, and other destinations. Combined with exceptional print quality, the scanner delivers fast, high quality output with automatic document collation. And with LDAP, you have direct access to contact and email data from an existing directory server. -
Outstanding features to support your day to day document requirements
The MC873 incorporates a customisable 7" color LCD touch screen with an intuitive menu system, enhanced help functionality, and Job Macro functions for frequent actions. Manage your documents effectively with our smart Extendable Platform (sXP) allowing seamless integration with document workflows and 3rd party solutions and a range of software, including SENDYS Explorer LITE, ABBYY FineReader Sprint, smartPrintSuperVision, and mobile printing solutions.
- OKI MC873DNV - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- LED (colour)
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 10000 pages
- Max Copying Speed
- Up to 35 ppm (mono) / up to 35 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Size
- A6 (105 x 148 mm) (min) - 297 x 431.8 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- A6 (105 x 148 mm) (min) - 297 x 1321 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, banner
- Standard Media Capacity
- 2005 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 450 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder
- Power
- AC 230 V (50/60Hz)
- 56.3 cm x 60 cm x 121.6 cm
- 89.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty with product registration
- Fax Type
- Plain paper
- LED - colour
- 75000 pages
- 10000 pages
- Display Diagonal Size
- 7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1.25 GB
- Hard Disk Drive
- 250 GB
Copying
- Max Copying Speed
- Preset Enlargements
- 400%
- Preset Reductions
- 25%
- Maximum Copies
- 999
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, IBM Proprinter, PDF 1.7, XPS, EPSON FX
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 9.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 400 pages
Fax Machine Features
- One-Touch Dialing
- 40 station(s)
- Speed Dialing
- 1000 station(s)
- Broadcast Transmission
- 100 stations
- Group dialling
Document & Media Handling
- Min Original Size
- A6 (105 x 148 mm)
- Max Original Size
- 297 x 431.8 mm
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- A6 (105 x 148 mm)
- Max Media Size
- A3
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International C4 (229 x 324 mm)
- 2005 sheets
- 100 sheets
- 450 sheets
- RADF - 100 sheets size: B5 (176 x 250 mm) - A3 (297 x 420 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: A6 (105 x 148 mm) - 297 x 1321 mm weight: 64 g/m² - 256 g/m² , Input tray - 300 sheets size: B5 (176 x 250 mm) - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , 3 x input tray - 535 sheets size: B5 (176 x 250 mm) - A3 (297 x 420 mm) weight: 64 g/m² - 176 g/m²
- Speed Details
- Copying: up to 35 ppm (A4) - B/W , Copying: up to 35 ppm (A4) - colour , Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (A4) - colour , Printing: up to 20 ppm (A3) - B/W , Printing: up to 20 ppm (A3) - colour , Scanning: up to 50 spm - B/W , Scanning: up to 50 spm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host - 4 pin USB Type A
- LDAP, SSL, TLS, IPsec, 802.1x, IP filtering, MAC address filtering
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.6.8 - 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
- Software Included
- OKI PrintSuperVision, OKI Color Swatch Utility, OKI Template Manager, OKI LPR, ABBYY FineReader 12 Sprint, SENDYS Explorer LITE
- Voltage Required
- 1400 Watt
- Power Consumption Standby
- 120 Watt
- Power Consumption Sleep
- 30 Watt
- Warm-Up Time
- 32 sec
- First Copy Out Time B/W
- 10 sec
- First Copy Out Time Colour
- 10 sec
- Included Accessories
- Caster base
- Consumables Included
- 1 x toner cartridge (black) - up to 2500 pages , 1 x toner cartridge (cyan) - up to 2500 pages , 1 x toner cartridge (magenta) - up to 2500 pages , 1 x toner cartridge (yellow) - up to 2500 pages
- ENERGY STAR Certified
- Limited warranty - 3 years
- 56.3 cm
- 60 cm
- 121.6 cm
- 89.3 kg
- Sound Emission
- 37 dBA (idle) / 54 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80%
OKI C822/831/841 Transfer Belt | In Stock | £106.63 |
OKI Yellow Drum for MC853/873 | In Stock | £142.40 |
OKI Magenta Drum for MC853/873 | In Stock | £142.40 |
OKI Toner Cartridge Black MC873 | In Stock | £106.48 |
OKI Toner Cartridge Magenta | In Stock | £150.46 |
OKI Toner Cartridge Cyan | In Stock | £150.46 |
OKI MC853/MC873 EP Cyan Ink Cartridge | In Stock | £142.40 |
OKI MC853/MC873 EP Black Ink Cartridge | In Stock | £142.40 |
OKI Toner Cartridge - Yellow | In Stock | £150.46 |
