The MC780 improves the way that documents are handled, managed and processed through an organization, delivering workflow efficiencies at every level.
Combining print, copy, scan, fax and document finishing (sorting and stapling) functionality in one high speed, ergonomic device, the MC780 offers efficient and secure document input, throughput and output.
This powerful multifunction printer features OKI's sXP (smart Extendable Platform), platform architecture to that enables seamless integration with existing systems and software solutions.
Flexibility that maximizes your investment
The MC780 is robust and efficient, having been designed to offer complete flexibility in choice with a range of high value features to meet your business needs. -
Improving business productivity at many levels of your organization
The MC780 is built to perform. With high speeds and flexible finishing options this MFP has in-built functionality to save end-user time. -
Highest level document and data security
IT security is a major concern for businesses today. The MC780 offers security and encryption to the highest industry standards. Sophisticated user authentication prevents unauthorized access and protects your corporate data whilst user access can be customized, allowing you to enable or disable functions easily. -
Reducing your impact on the environment
OKI technology and in-built eco features ensure this is amongst the most environmentally friendly MFPs available.
- OKI MC780dfnfax - multifunction printer - colour - with 500-sheets Finisher
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- LED (colour)
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 10000 pages
- Max Copying Speed
- Up to 40 ppm (mono) / up to 40 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 600 dpi
- Original Size
- 148.5 x 210 mm (min) - 216 x 356 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 64 x 127 mm (min) - 216 x 1321 mm (max)
- Media Type
- Envelopes, plain paper, labels
- Standard Media Capacity
- 630 sheets
- Max Media Capacity
- 3160 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 650 sheets
- Stacker
- Included
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder, scan to network, save to HDD, sXP (smart Extendable Platform)
- Power
- AC 230 V (50/60Hz)
- 52.2 cm x 60.4 cm x 81.1 cm
- 60 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty with product registration
- Bundled with
- 500-sheets Finisher
- Fax Type
- Plain paper
- LED - colour
- 100000 pages
- 10000 pages
- Display Features
- Touch screen
- Interface
- Bundled with
- Standard Memory
- 2 GB
- Hard Disk Drive
- 160 GB
Copying
- Max Copying Speed
- Preset Enlargements
- 400%
- Preset Reductions
- 25%
- Maximum Copies
- 999
- Copying Features
- ID Card Copy
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PCL 5c
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- First Print Out Time B/W
- 8 sec
- First Print Out Time Colour
- 8 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 1000 pages
Fax Machine Features
- Speed Dialing
- 1000 station(s)
- Broadcast Transmission
- 400 stations
- Group dialling
Document & Media Handling
- Min Original Size
- 148.5 x 210 mm
- Max Original Size
- 216 x 356 mm
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 64 x 127 mm
- Max Media Size
- A4
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 250 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
- 630 sheets
- 3160 sheets
- 100 sheets
- 650 sheets
- RADF - 100 sheets - 216 x 356 mm weight: 60 g/m² - 105 g/m² , Bypass tray - 100 sheets size: 64 x 127 mm - 216 x 1321 mm weight: 64 g/m² - 250 g/m² , Input tray - 530 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Stacker / stapler - 50 sheets , Output tray - 100 sheets
- Speed Details
- Copying: up to 40 ppm (A4) - B/W , Copying: up to 40 ppm (A4) - colour , Printing: up to 40 ppm (A4) - B/W , Printing: up to 40 ppm (A4) - colour , Scanning: up to 40 ipm - B/W , Scanning: up to 40 ipm - colour
Finishing Equipment
- Stacker
- Included
- Stapler
- Included
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- LDAP, Secure Print, SSL, Apple Bonjour, TLS, IP filtering, ARP, MAC address filtering
- Operating System Support
- UNIX, Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, Apple Mac OS X 10.4, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista SP1, MS Windows 7 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista SP2, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Vista SP2 64-bit Edition, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2008 SP1, MS Windows Server 2003 SP2, Windows 8 64-bit
- Software Included
- Drivers & Utilities, OKI Job Accounting, OKI PrintSuperVision, OKI Template Manager
- Voltage Required
- 800 Watt
- Power Consumption Standby
- 130 Watt
- Power Consumption Sleep
- 2 Watt
- Warm-Up Time
- 60 sec
- First Copy Out Time B/W
- 13 sec
- First Copy Out Time Colour
- 13 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 4800 pages , 1 x toner cartridge (cyan) - up to 4800 pages , 1 x toner cartridge (magenta) - up to 4800 pages , 1 x toner cartridge (yellow) - up to 4800 pages
- GS
- ENERGY STAR Certified
- Limited warranty - 3 years - on-site
- 52.2 cm
- 60.4 cm
- 81.1 cm
- 60 kg
- Sound Emission
- 37 dBA (idle) / 57 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80%
OKI MC760/770/780 Magenta Toner 6K | In Stock | £123.41 |
OKI MC760/770/780 Black Toner 8K | In Stock | £61.90 |
