OKI MC770dn Colour Laser Multifunction Printer
Quicklinx: 9G2PWS00 Mfr#: 01334303
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Wireless Capability: [N/A]
Technology: Laser
£1,006.51 ex VAT
£1,207.81 inc VAT
The MC770 multifunction printers provide high-demand performance and reliability, while maintaining a low cost per copy and low total cost of ownership. Highlighted features include high print and copy speeds (42/42 ppm), legal flatbed scanners, high toner yields, and embedded open API platform for document management. These MFPs can additionally be configured with expanded paper trays and feeders, internal finishing capabilities, as well as a dealer - installed wireless functionality.
OKI MC770dnfax - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
LED (colour)
Max Copying Speed
Up to 36 ppm (mono) / up to 34 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
216 x 1321 mm (max)
Media Type
Envelopes, plain paper, labels
Standard Media Capacity
630 sheets
Max Media Capacity
3160 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
520 sheets
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, scan to network, sXP (smart Extendable Platform)
AC 230 V (50/60Hz)
52.2 cm x 60.4 cm x 67.5 cm
50 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3 years warranty with product registration
Fax Type
Plain paper
Printing Technology
LED - colour
Display Features
Touch screen
Standard Memory
2 GB
Hard Disk Drive
160 GB
Copying
Max Copying Speed
Preset Enlargements
400%
Preset Reductions
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
ID Card Copy
Printing
Max Printing Speed
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
First Print Out Time B/W
8 sec
First Print Out Time Colour
9 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 1000 pages
Fax Machine Features
Speed Dialing
1000 station(s)
Broadcast Transmission
400 stations
Group dialling
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
100 sheets
Max Media Size
A4
Min Media Weight
64 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
630 sheets
Max Media Capacity
3160 sheets
100 sheets
520 sheets
ADF - 100 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 100 sheets - 216 x 1321 mm weight: 64 g/m² - 250 g/m² , Input tray - 530 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Output tray - 500 sheets , Stapler - 20 sheets
Speed Details
Copying: up to 36 ppm (A4) - B/W , Copying: up to 34 ppm (A4) - colour , Printing: up to 36 ppm (A4) - B/W , Printing: up to 34 ppm (A4) - colour , Scanning: up to 40 ipm - B/W , Scanning: up to 40 ipm - colour
Finishing Equipment
Stapler
Included
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, Secure Print, SSL, Apple Bonjour, TLS, IP filtering, ARP, MAC address filtering
Operating System Support
UNIX, Linux, MS Windows XP SP2 or later, Apple Mac OS X 10.4, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista SP1, MS Windows 7 64-bit Edition, MS Windows Vista SP2, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Vista SP2 64-bit Edition, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2008 SP1, MS Windows Server 2003 SP2, Windows 8 64-bit
Software Included
Drivers & Utilities, OKI PrintSuperVision, OKI Template Manager
AC 230 V (50/60Hz)
800 Watt
Power Consumption Standby
130 Watt
Power Consumption Sleep
2 Watt
Warm-Up Time
60 sec
First Copy Out Time B/W
13 sec
First Copy Out Time Colour
13 sec
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
GS
ENERGY STAR Certified
Limited warranty - 3 years - on-site
52.2 cm
60.4 cm
67.5 cm
50 kg
Sound Emission
37 dBA (idle) / 57 dBA (operating)
10 °C
32 °C
20 - 80%
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Laser
Max Print Speed: [N/A]
Brand: OKI
Price Range Ex VAT: 1000 - 1500
