OKI MC563dn Colour Laser 30ppm Multifunction Printer
Quicklinx: D1YQWS00 Mfr#: 46552701
Functionality: Copier, Printer, Scanner, Fax
Output Type: Colour
Technology: Laser
Max Print Speed: 30ppm
£358.92 ex VAT
£430.70 inc VAT
If you thought secure document management was only possible for large corporates, think again. The MC500 Series makes all the benefits of smart multifunction printers (MFPs) affordable for small to medium-sized businesses and workgroups. Plus a powerful engine enabling ultra-fast, high-quality color printing.
OKI MC563dn - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
LED (colour)
Monthly Duty Cycle (max)
60000 pages
Recommended Monthly Volume
6000 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Type
Envelopes, plain paper, cards, photo paper, banner
Standard Media Capacity
350 sheets
Max Media Capacity
1410 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
Office Machine Features
Save to USB flash drive, scan to e-mail, sXP (smart Extendable Platform), scan to FTP, scan to PC, scan to CIFS, scan to HTTP, remote scan
AC 230 V (50/60Hz)
42.7 cm x 57.6 cm x 47.2 cm
31 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty with product registration
Fax Type
Plain paper
Printing Technology
LED - colour
60000 pages
6000 pages
Standard Memory
1 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, IBM Proprinter, PDF 1.7, XPS, PCL 6 (XL 3.0), EPSON FX
Image Enhancement Technology
Auto Color Balance, Photo Enhance via driver
Automatic Duplexing
First Print Out Time B/W
7.5 sec
First Print Out Time Colour
7.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 8000 pages
PC Faxing
Fax Machine Features
One-Touch Dialing
40 station(s)
Speed Dialing
1000 station(s)
Broadcast Transmission
100 stations
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
50 sheets
Max Media Size
A4
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), 210 x 1320 mm, 75 x 125 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Borderless Photo Sizes
100 x 150 mm, 125 x 175 mm
350 sheets
Max Media Capacity
1410 sheets
100 sheets
150 sheets
RADF - 50 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Input tray - 250 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 176 g/m² , Bypass tray - 100 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Scanning: up to 30 ppm - B/W , Scanning: up to 30 ppm - colour
1 x USB 2.0 , 1 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, IP filtering, IC Card authentication, MAC address filtering
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.8.5 - 10.11
Software Included
OKI PrintSuperVision, OKI Color Swatch Utility, OKI Color Correct Utility, OKI Template Manager, OKI Configuration Tool, OKI Driver Installer, OKI Firmware Update Tool, OKI Front End Installer, OKI LPR Utility, OKI Maintenance Utility, OKI Network Card Setup, OKI Network Extension, OKI PDF Print Direct, OKI Print Job Accounting Client, OKI Profile Assistant, OKI PS Gamma Adjuster, OKI Scanner Driver (ICA), OKI Universal FAX Driver, OKI Universal Scanner Driver (TWAIN), OKI Universal Scanner Driver (WIA), OKI Web Driver Installer
AC 230 V (50/60Hz)
640 Watt
Power Consumption Standby
100 Watt
Power Consumption Sleep
1.5 Watt
First Copy Out Time B/W
12 sec
First Copy Out Time Colour
12 sec
Consumables Included
1 x Cartridge (black) - up to 1500 pages , 1 x Cartridge (cyan) - up to 1500 pages , 1 x Cartridge (magenta) - up to 1500 pages , 1 x Cartridge (yellow) - up to 1500 pages
ENERGY STAR Certified
Limited warranty - 3 years
42.7 cm
57.6 cm
47.2 cm
31 kg
Sound Emission
37 dBA (idle) / 54 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
Functionality: Printer
Functionality: Scanner
Functionality: Fax
Output Type: Colour
Technology: Laser
Max Paper Size: A4 (210 x 297 mm)
Brand: OKI
