OKI MC562dnw Colour Laser Multifunction Printer
Quicklinx: 9988WS00 Mfr#: 01331501
For businesses that require 4-in-1 multifunctional devices that offer a low total cost of ownership, high quality document output and management at fast speeds, the MC562dnw is the smart choice. Combining a wide range of functions and useful business tools, this device offers superior printing speeds, media flexibility and high capacity toners to support larger workgroups.
The MC562dnw offers as standard, wireless network-ready connectivity, duplex printing, scanning/copying and faxing, with an automatic RADF and superior quality high definition color and mono A4 printing, that enables you to produce professional looking documents in-house.
  • Print smart, saving time and money through printing in-house
    Management and printing of your documents is so much simpler with the MC562dnw, combining high definition, color printing with tools that give you the ability to create a full range of documents in-house, allowing you to effectively manage what you print and when you print it.
  • Sharp, accurate scanning with useful document management functionality
    Providing sharp, fast and accurate scanning, the MC562dnw enables you to digitize your documents clearly and with ease. Scan directly to a USB or network TWAIN, whilst LDAP provides direct access to contact and email data from an existing directory server.
  • Efficient, cost saving functionality
    The MC562dnw is built on award winning digital LED technology that is inherently energy efficient with many features and functions that reduce your ongoing costs, including eco and deep sleep modes, plus auto off mode that reduces energy consumption to 0.5 W when not in use.
  • Fast, fax with enhanced functionality
    The MC562dnw offers enhanced fax functionality, delivering Super G3 speed with intuitive controls that improve efficiency and document management. Fax double-sided documents, automatically forward received faxes to email addresses or folders and send faxes directly from your PC or over the internet.
  • Simple one touch copying with outstanding results
    Combining LED scanning and printing for clear, sharp and fast results the MC562dnw offers superior and simple copying through an easy to use user interface with one touch buttons for all functions. Save regular copy settings and with ID copy you can copy double sided ID cards on a single side.
  • Reducing your total cost of ownership
    The MC562dnw is built to offer considerable cost savings over its lifespan. Combining exceptional energy efficiencies with high capacity toner cartridges and many paper saving functions, this really is a device that can enhance your business efficiencies.
OKI MC562dnw - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
LED (colour)
Monthly Duty Cycle (max)
60000 pages
Recommended Monthly Volume
5000 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 26 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Display
3.5"
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
210 x 1320 mm (max)
Media Type
Envelopes, plain paper, photo paper, banner
Standard Media Capacity
350 sheets
Max Media Capacity
880 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, QWERTY keypad
AC 230 V (50/60Hz)
44.4 cm x 42.7 cm x 50.9 cm
29 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Fax Type
Plain paper
Printing Technology
LED - colour
60000 pages
5000 pages
Display Diagonal Size
3.5"
Standard Memory
256 MB
Max Supported Memory
768 MB
Supported Flash Memory
SDHC Memory Card
Copying
Max Copying Speed
Preset Enlargements
400%
Preset Reductions
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, IBM Proprinter
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
First Print Out Time B/W
7.5 sec
First Print Out Time Colour
8 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 200 pages
Fax Machine Features
One-Touch Dialing
16 station(s)
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Fax forwarding, group dialling
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
50 sheets
Max Media Size
A4
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 75 x 125 mm, 125 x 175 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
350 sheets
Max Media Capacity
880 sheets
100 sheets
150 sheets
ADF - 50 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 100 sheets - 210 x 1320 mm weight: 64 g/m² - 220 g/m² , Input tray - 250 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 176 g/m² , Output tray - 150 sheets
Speed Details
Copying: up to 30 ppm - B/W , Copying: up to 26 ppm - colour , Printing: up to 30 ppm (A4) - B/W , Printing: up to 26 ppm (A4) - colour , Scanning: up to 20 ppm - colour , Scanning: up to 30 ppm - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
LDAP, Secure Print, SSL, Apple Bonjour, TLS, WPA, WPA2, IPsec, 802.1x, TKIP, AES, WPS, IP filtering, ARP, MAC address filtering
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition, Windows 8, Windows 8 64-bit, Apple Mac OS X 10.3.9 - 10.8
Software Included
OKI Job Accounting, OKI PrintSuperVision, OKI Color Swatch Utility, OKI Color Correct Utility, OKI Template Manager, OKI LPR, Nuance PaperPort SE 11, Nuance OmniPage SE 16
AC 230 V (50/60Hz)
570 Watt
Power Consumption Standby
100 Watt
Power Consumption Sleep
1.5 Watt
Warm-Up Time
60 sec
First Copy Out Time B/W
12 sec
First Copy Out Time Colour
14 sec
4 GB SDHC memory card
Consumables Included
1 x toner cartridge (black) - up to 2000 pages , 1 x toner cartridge (cyan) - up to 2000 pages , 1 x toner cartridge (magenta) - up to 2000 pages , 1 x toner cartridge (yellow) - up to 2000 pages
Supported Windows 7 Features
Windows HD Imaging
ENERGY STAR Certified
Limited warranty - 3 years - on-site
44.4 cm
42.7 cm
50.9 cm
29 kg
Sound Emission
33 dBA (idle) / 54 dBA (operating)
10 °C
32 °C
20 - 80%
