Digital color printers from OKI Printing Solutions provide high-quality, tabloid-extra color output. With the C9655 Series Digital Color printers, you can improve the quality of your output and increase productivity - even as you lower your expenses.
- OKI C9655n - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 76 kg
- Media Size Class
- A3
- Max Media Size
- A3 Nobi (328 x 453 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 328 mm x 1200 mm
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 36 ppm - colour - A4 (210 x 297 mm) , Up to 21 ppm - B/W - A3 (297 x 420 mm) , Up to 19 ppm - colour - A3 (297 x 420 mm)
- Max Resolution (B&W)
- 1200 x 600 dpi
- Max Resolution (Colour)
- 1200 x 600 dpi
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- Interface
- Parallel, USB, Gigabit LAN
- Processor
- PowerPC 750 (G3) 800 MHz
- RAM Installed (Max)
- 512 MB (1 GB)
- Language Simulation
- PCL 5C, PostScript 3, PCL XL, PDF 1.6
- Media Type
- Plain paper, business cards, banners, heavy-weight paper
- Total Media Capacity
- 760 sheets
- Media Handling
- 530-sheet input tray, 230-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 5000 - 15000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet, EtherTalk - internal
- Printer Features
- Optional duplex, Single Pass Colour Digital technology, HD Colour technology
- System Requirements
- Novell NetWare 3.x, Novell NetWare 4.x, Novell NetWare 5.x, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Novell NetWare 6, Microsoft Windows Server 2003 Standard Edition, Microsoft Windows Server 2003, Microsoft Windows 2000 Server SP3 or later, Microsoft Windows 2000 Professional SP3 or later, Microsoft Windows 2000 Advanced Server SP3 or later, Microsoft Windows 2000 SP3 or later, Apple MacOS X 10.2.8 or later, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X on Intel 10.4.4 or later, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Citrix MetaFrame Presentation Server 4.0
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty with product registration
- 65.5 cm x 62.3 cm x 47.1 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 600 dpi
- 1200 x 600 dpi
- PostScript Support
- Included
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10.5 sec
- Fonts Included
- 86 x PCL , 136 x PostScript , 10 x TrueType , 1 x bitmapped
- Printer Features
- Media Handling
- Processor
RAM
- 512 MB / 1 GB (max)
Media Handling
- Media Path Type
- Curved, straight
- Media Type
- Media Size Class
- A3
- Max Media Size
- 76 mm x 127 mm
- 328 mm x 1200 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), A3 Nobi (328 x 453 mm)
- Media Weight
- 64 g/m² - 330 g/m²
- 760 sheets
- Media Feeders
- 1 x automatic - 230 sheets - 320 x 1200 mm weight: 64 g/m² - 330 g/m² , 1 x automatic - 530 sheets - 328 x 457 mm weight: 64 g/m² - 216 g/m²
- Max Media Capacity
- 2880 sheets
- Output Trays Capacity
- 700 sheets
Duty Cycle
- 150000 pages
- Networking
- Print server - internal
- Data Link Protocol
- TCP/IP, UDP/IP, NetBEUI/NetBIOS, ICMP/IP, LPR/LPD, ARP, SMTP, FTP, AARP, AEP, ATP, BOOTP, DDP, DHCP, DNS, JetDirect, NBP, PAP, POP3, RARP, RTMP, ZIP, Bonjour, SMB
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, HTTP, NDPS, HTTPS
- SSL, NDS Authentication over IP, TLS, 802.1x
- Expansion Bays
- 1 (total) / 1 (free) x internal
- Expansion Slots
- Memory
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel - 36 PIN Centronics
- Consumables Included
- 1 x toner cartridge (black) - up to 7500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 7500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 7500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 7500 pages ISO/IEC 19798
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 750 Watt
- Power Consumption Stand by / Sleep
- 200 Watt
- Software Included
- Driver, OKI Print Control Client, OKI Print Control Server, OKI PrintSuperVision.net, OKI Template Manager 2006, OKI Color Correct, OKI NDPS Gateway, OKI PS Gamma Adjuster
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 42 dBA
- Sound Emission (Operating)
- 54 dBA
- 65.5 cm
- 62.3 cm
- 47.1 cm
- 76 kg
OKI C9655 Magenta Toner | In Stock | £339.64 |
OKI C9655 Black Toner | In Stock | £135.84 |
