Your basket is empty
OKI C9655hdtn Colour LED Printer
Quicklinx: 7QNWWS00 Mfr#: 01307801
Digital color printers from OKI Printing Solutions provide high-quality, tabloid-extra color output. With the C9655 Series Digital Color printers, you can improve the quality of your output and increase productivity - even as you lower your expenses.
OKI C9655hdtn - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
133 kg
Media Size Class
A3
Max Media Size
A3 Nobi (328 x 453 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
328 mm x 1200 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 36 ppm - colour - A4 (210 x 297 mm) , Up to 21 ppm - B/W - A3 (297 x 420 mm) , Up to 19 ppm - colour - A3 (297 x 420 mm)
Max Resolution (B&W)
1200 x 600 dpi
Max Resolution (Colour)
1200 x 600 dpi
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
Parallel, USB, Gigabit LAN
PowerPC 750 (G3) 800 MHz
RAM Installed (Max)
512 MB (1 GB)
Hard Drive
40 GB
Language Simulation
PCL 5C, PostScript 3, PCL XL, PDF 1.6
Media Type
Plain paper, business cards, banners, heavy-weight paper
Total Media Capacity
2350 sheets
Media Handling
530-sheet input tray, 230-sheet multipurpose tray, 1590-sheet high-capacity feeder
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
5000 - 15000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet, EtherTalk - internal
Printer Features
Single Pass Colour Digital technology, HD Colour technology
AC 230V
Novell NetWare 3.x, Novell NetWare 4.x, Novell NetWare 5.x, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Novell NetWare 6, Microsoft Windows Server 2003 Standard Edition, Microsoft Windows Server 2003, Microsoft Windows 2000 Server SP3 or later, Microsoft Windows 2000 Professional SP3 or later, Microsoft Windows 2000 Advanced Server SP3 or later, Microsoft Windows 2000 SP3 or later, Apple MacOS X 10.2.8 or later, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X on Intel 10.4.4 or later, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Citrix MetaFrame Presentation Server 4.0
Microsoft Certification
Compatible with Windows 7
3 years warranty with product registration
65.5 cm x 62.3 cm x 87.3 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 600 dpi
1200 x 600 dpi
Automatic Duplexing
PostScript Support
Included
First Print Out Time B/W
9 sec
First Print Out Time Colour
10.5 sec
Language Simulation
Fonts Included
86 x PCL , 136 x PostScript , 10 x TrueType , 1 x bitmapped
Printer Features
Media Handling
RAM
RAM Installed (Max)
512 MB / 1 GB (max)
Storage
Hard Drive
40 GB
Media Handling
Media Path Type
Curved, straight
Media Type
Media Size Class
A3
Max Media Size
76 mm x 127 mm
328 mm x 1200 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), A3 Nobi (328 x 453 mm)
Media Weight
64 g/m² - 330 g/m²
2350 sheets
Media Feeders
1 x automatic - 230 sheets - 320 x 1200 mm weight: 64 g/m² - 330 g/m² , 1 x automatic - 530 sheets - 328 x 457 mm weight: 64 g/m² - 216 g/m² , 1 x automatic - 1590 sheets - 328 x 457 mm weight: 64 g/m² - 216 g/m²
Max Media Capacity
2880 sheets
Output Trays Capacity
700 sheets
Duty Cycle
150000 pages
5000 - 15000 pages
Print server - internal
Network / Transport Protocol
TCP/IP, UDP/IP, NetBEUI/NetBIOS, ICMP/IP, LPR/LPD, ARP, SMTP, FTP, AARP, AEP, ATP, BOOTP, DDP, DHCP, DNS, JetDirect, NBP, PAP, POP3, RARP, RTMP, ZIP, Bonjour, SMB
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, HTTP, NDPS, HTTPS
Security Protocols & Features
SSL, NDS Authentication over IP, TLS, 802.1x
Expansion Bays
1 (total) / 1 (free) x internal
Expansion Slots
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel - 36 PIN Centronics
Consumables Included
1 x toner cartridge (black) - up to 7500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 7500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 7500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 7500 pages ISO/IEC 19798
Power supply - internal
AC 230V
Frequency Required
50 Hz
750 Watt
Power Consumption Stand by / Sleep
200 Watt
Software Included
Driver, OKI Print Control Client, OKI Print Control Server, OKI PrintSuperVision.net, OKI Template Manager 2006, OKI Color Correct, OKI NDPS Gateway, OKI PS Gamma Adjuster
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
42 dBA
Sound Emission (Operating)
54 dBA
65.5 cm
62.3 cm
87.3 cm
133 kg
7QNW OKI Magenta drum for C9600 / C9800 series 30000 yield In Stock £124.67
7QNW OKI Yellow drum for C9600 / C9800 series 30000 yield In Stock £123.58
7QNW OKI Black drum for C9600 / C9800 series 30000 yield In Stock £124.67
7QNW OKI Cyan drum for C9600 / C9800 series 30000 yield In Stock £133.59
7QNW OKI Waste toner system c6900/800 In Stock £9.32
7QNW OKI OKI FUSER UNIT C96/98 In Stock £127.10
7QNW OKI C9655 Yellow Toner In Stock £267.52
7QNW OKI C9655 Magenta Toner In Stock £267.52
7QNW OKI C9655 Cyan Toner In Stock £267.52
7QNW OKI C9655 Black Toner In Stock £107.01
