Smallest A3 colour printer where space is a premium offering outstanding print quality
Key features-
- Smallest footprint A3 printer on the market perfect for retail
- Excellent media flexibility - A6 to A3 and up to 1321mm banners
- Up to 35ppm colour print speed
- Fast duplex printing (optional on n variants)
- Paper capacity up to 1990 sheets and media weights between 64 and 256gsm
- Excellent 1200 x 1200dpi print quality (C843dn)
- Citrix XenApp 7.6 compatibility - ideal for virtual network environment
Advanced connectivity-
- Wireless Direct offers safe simultaneous connection of wired and wireless networking
- Optional Wireless LAN Module available
- Gigabit Ethernet enables fast transfer of large colour files across the network
- Google Cloud Print 2.0 ready enabling printing on the move
Easy to use-
- Easy to set-up and get started
- Store templates and documents on the device for all users to print without authentication (Shared Print)
- When new features are available you can update the device via the OKI portal
Cost and energy saving-
- Print marketing materials in-house thanks to outstanding print quality and media flexibility
- Deep Sleep mode saves energy Auto-Off mode automatically powers down to less than 0.5W when not in use
- Toner Save to reduce cost when printing draft or internal documents
- Duplex printing reduces paper usage • Mono only printing when colour cartridges are empty
- OKI C843dn - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 40 kg
- Localisation
- North America
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Min Media Size (Custom)
- 148.5 mm x 182 mm
- Max Media Size (Custom)
- 297 mm x 1321 mm
- Print Speed
- Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm) , Up to 20 ppm - B/W - A3 (297 x 420 mm) , Up to 20 ppm - colour - A3 (297 x 420 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- RAM Installed (Max)
- 512 MB (768 MB)
- Flash Memory Installed (Max)
- (16 GB)
- Language Simulation
- PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, XPS, SIDM, PCL XL 3.0, PDF 1.7
- Barcodes
- Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 400 sheets
- Media Handling
- 100-sheet multipurpose tray, 300-sheet input tray
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 5000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Apple MacOS X 10.8.5 - 10.11
- 3-year warranty with product registration
- 44.9 cm x 55.2 cm x 36 cm
- Printer Type
- Localisation
- North America
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 9.5 sec
- Fonts Included
- 87 x scalable PCL , 80 x PostScript , 1 x bitmapped PCL , 1 x barcode
- Barcodes
- Media Handling
RAM
- 512 MB / 768 MB (max)
Flash Memory
- Flash Memory
- 16 GB (max)
Card Reader
- Supported Flash Memory Cards
- SDHC Memory Card
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- 148.5 mm x 182 mm
- 297 mm x 1321 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), International C4 (229 x 324 mm)
- Media Weight
- 64 g/m² - 256 g/m²
- 400 sheets
- Media Feeders
- 1 x automatic - 300 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets weight: 64 g/m² - 256 g/m²
- Max Media Capacity
- 2005 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 75000 pages
- 5000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, HTTP
- SSL, TLS, IPsec, 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2500 pages ISO/IEC 19798
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 700 Watt
- Power Consumption Stand by
- 12 Watt
- Power Consumption Sleep
- 1 Watt
- Software Included
- OKI PrintSuperVision, OKI LPR, OKI Web Driver Installer, OKI Profile Assistant, OKI Color Correct, OKI Color Swatch Utility, OKI Network Extension, OKI Template Manager, OKI PS Gamma Adjuster, OKI Print Job Accounting, OKI Configuration Tool, OKI Firmware Update Tool, OKI Network Card Setup
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 32 dBA
- Sound Emission (Operating)
- 52 dBA
- 44.9 cm
- 55.2 cm
- 36 cm
- 40 kg
OKI C831/C841 Fuser Unit | In Stock | £95.78 |
OKI C822/831/841 Transfer Belt | In Stock | £92.77 |
