The C831 is the ideal A3/A4 color printer for small to medium businesses or workgroups looking for fast, high quality, high volume, print on demand capabilities, in-house. With fast print speeds and high capacity toners, you can rely on this device to deliver on your day-to-day business printing needs.
Fast, robust and superb color print quality
The C831 is built on tried and tested LED technology that your business can rely on to deliver over and over again. -
Excellent media flexibility to support your business
The C831 provides complete flexibility, enabling users to print on a wide range of media sizes, formats and paper weights.
- OKI C831n - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 37 kg
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Max Media Size (Custom)
- 297 mm x 1321 mm
- Print Speed
- Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm) , Up to 20 ppm - B/W - A3 (297 x 420 mm) , Up to 20 ppm - colour - A3 (297 x 420 mm)
- Max Resolution (B&W)
- 1200 x 600 dpi
- Max Resolution (Colour)
- 1200 x 600 dpi
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- Interface
- USB, LAN, USB host
- Processor
- 800 MHz
- RAM Installed (Max)
- 256 MB (768 MB)
- Card Reader
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, SIDM, PDF 1.8
- Barcodes
- OCR-A, OCR-B, ZIP
- Media Type
- Envelopes, plain paper, banners
- Total Media Capacity
- 400 sheets
- Media Handling
- 100-sheet multipurpose tray, 300-sheet input tray
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 1500 - 5000 pages
- Networking
- Print server - Ethernet, Fast Ethernet - internal
- Printer Features
- Optional duplex
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.3.9 - 10.7
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty with product registration
- 44.9 cm x 55.2 cm x 36 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 600 dpi
- 1200 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 9.5 sec
- Fonts Included
- 87 x scalable PCL , 80 x scalable PostScript , 1 x bitmapped PCL , 1 x barcode
- Barcodes
- OCR-A, OCR-B, ZIP
- Colour Management Features
- ICC Color Profiles
- Printer Features
- Optional duplex
- Media Handling
- Processor
- 800 MHz
RAM
- 256 MB / 768 MB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SDHC Memory Card
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- 297 mm x 1321 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), International C4 (229 x 324 mm)
- Media Weight
- 64 g/m² - 256 g/m²
- 400 sheets
- Media Feeders
- 1 x automatic - 300 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets - 297 x 1321 mm weight: 64 g/m² - 256 g/m²
- Max Media Capacity
- 1990 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 75000 pages
- 1500 - 5000 pages
- Networking
- Print server - internal
- Data Link Protocol
- Remote Management Protocol
- SNMP 3, HTTPS
- Secure Print, SSL, TLS, 802.1x, IP filtering, MAC address filtering
- Expansion Slots
- Memory
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x direct print port - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2500 pages ISO/IEC 19798
- Supported Windows 7 Features
- Windows HD Imaging
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 700 Watt
- Power Consumption Stand by / Sleep
- 100 Watt
- Software Included
- OKI PrintSuperVision, OKI LPR, OKI PrintSuperVision.net, OKI Web Driver Installer, OKI Web Print, OKI Profile Assistant, OKI Storage Device Manager, OKI Color Correct, OKI Color Swatch Utility, OKI Template Manager, OKI PDF Direct Utility, OKI PS Gamma Adjuster, OKI Color Access Policy Manager
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 32 dBA
- Sound Emission (Operating)
- 52 dBA
- 44.9 cm
- 55.2 cm
- 36 cm
- 37 kg
OKI C831/841 Black Toner 10K | In Stock | £88.64 |
OKI C831/841 Cyan Toner 10K | In Stock | £192.09 |
OKI C831/841 Magenta Toner 10K | In Stock | £192.09 |
OKI C831/841 Yellow Toner 10K | In Stock | £192.09 |
OKI C822/831/841 MAGENTA Image Drum 30K | In Stock | £141.48 |
OKI C822/831/841 Cyan Image Drum 30K | In Stock | £141.48 |
OKI C822/831/841 Black Image Drum 30K | In Stock | £141.48 |
OKI C822/831/841 Yellow Image Drum 30K | In Stock | £141.48 |
OKI C831/C841 Fuser Unit | In Stock | £95.99 |
OKI C822/831/841 Transfer Belt | In Stock | £92.96 |
