OKI C542dn-2AC A4 Colour Laser Printer
Quicklinx: CGRPWS00 Mfr#: 46552602
Type: Printer
Functionality: Printer
Wireless Capability: Wired
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Hurry, only 1 left in stock!
£335.74 ex VAT
£402.88 inc VAT
Small businesses and workgroups can now enjoy the transforming benefits of smart printers. The C542dn is ultra-fast, powerful and equipped with the latest security features, incorporating 7" colour LCD touch screen technology and OKI’s open architecture smart extendable platform (sXP) which provides exceptional potential for connectivity and customisation. A wide range of media compatibility, intuitive storage and easy updates make the C542dn a perfect fit for any small business.
Productivity and connectivity - Keeping productivity high and seamlessly connected
With print speeds of 30ppm in colour and 1GB RAM memory ensures busy workgroups get fast results, helping them keep productive. Gigabit Ethernet, optional Wireless LAN and printing directly from smartphones or tablets improves connectivity options.
  • Impressive print speeds of 30ppm in colour
  • GB RAM memory for trouble-free printing of graphics-intensive documents
  • Gigabit Ethernet enables fast transfer of large colour files across the network
  • Store templates and documents on the device for all users to print without authentication (Shared Print)
  • Mobile printing from smartphones and tablets, Google Cloud Print 2.0 ready, as well as being compatible with AirPrint by Apple Inc.
  • Wireless Direct feature offers safe simultaneous connection of wired and wireless networking
  • Optional Wireless LAN Module available
Important security features - Keep documents confidential and access stored print jobs when required
Helping businesses to stay in control of printing output and cost, the C542dn includes a wide range of cost and time-saving features.
  • Keep documents confidential with Private Print and optional Card Release, so users can view all print jobs before selecting which ones to print
  • Internet Protocol Security (IPSec) compliance, ensuring securing that documents are safely sent and received
smart Extendable Platform (sXP) – Allows for connectivity to pull printing fleet and other devices
The C542dn gives businesses access to a wide range of new features. Connecting to existing pull printing fleets and third-party IT applications is simple, bringing the power of smart technology to any workgroup.
  • OKI's open architecture sXP for workflow integration and document management
  • Intuitive, customisable 7" colour LCD touch screen
  • Potential to run third-party applications on the device, such as PaperCut MF and Drivve Image
  • Access to document management software SENDYS Explorer LITE at no extra cost
  • SENDYS Output Manager option, allowing administrator to manager all users’ print jobs, reducing costs and environmental impact
  • Software development kit (SDK) available for rapid implementation of a custom solution
Simple to set-up, use and own - Low power consumption and duplex printing as standard
The C542dn is easy to set-up and use with a range of eco-friendly features that save energy and help to lower running costs, including duplex printing as standard.
  • Video guidance for installation and changing consumables
  • When new features are available you can update the device via the OKI portal
  • Trouble-shooting on the device screen and via OKI Mobile Print app
  • Quiet mode ideal for smaller offices
  • Deep Sleep mode saves energy, Auto-Off mode automatically powers down to less than 0.5W when not in use
  • Toner Save to reduce costs, when printing draft or internal documents
  • Duplex printing reduces paper usage
  • LED technology means no moving parts for a longer life
  • Free consumables recycling programme
OKI C542dn - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
24 kg
Canada, Americas
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Max Media Size (Custom)
1320 mm
Print Speed
Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
RAM Installed (Max)
1 GB
Flash Memory Installed (Max)
3 GB
Language Simulation
PCL 5C, PostScript 3, EPSON FX, PCL 6, IBM ProPrinter, XPS, SIDM, PCL XL 3.0, PDF 1.7
Barcodes
Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
Media Type
Envelopes, labels, plain paper, banners, cards
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet input tray
Monthly Duty Cycle (max)
60000 pages
Recommended Monthly Volume
6000 pages
Print server
AC 230V
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Apple MacOS X 10.8.5 - 10.11
3 years warranty with product registration
42.7 cm x 57.1 cm x 27.9 cm
Printer Type
Canada, Americas
Printer
Print Speed
Built-in Devices
7 inch LCD touch screen
Wired
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
7.5 sec
First Print Out Time Colour
7.5 sec
Language Simulation
Fonts Included
87 x scalable PCL , 80 x scalable PostScript , 1 x bitmapped PCL , 1 x barcode
Barcodes
Colour Management Features
ICC Color Profiles
Media Handling
RAM
RAM Installed (Max)
1 GB
Flash Memory
Flash Memory
3 GB
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
1320 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Card / Label Sizes
US 4 x 6 Card (10 x 15 cm), US 3 x 5 Card (76 x 127 mm)
Media Weight
64 g/m² - 220 g/m²
350 sheets
Media Feeders
1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 176 g/m² , 1 x automatic - 100 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m²
Max Media Capacity
880 sheets
Output Trays Capacity
150 sheets
Duty Cycle
60000 pages
6000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, HTTP
Security Protocols & Features
SSL, TLS, IPsec, 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 2000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2000 pages ISO/IEC 19798
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
670 Watt
Power Consumption Stand by
90 Watt
Power Consumption Sleep
1.1 Watt
Software Included
OKI PrintSuperVision, OKI LPR, OKI Web Driver Installer, OKI Profile Assistant, OKI Color Correct, OKI Color Swatch Utility, OKI Network Extension, OKI Template Manager, OKI PDF Print Direct, OKI PS Gamma Adjuster, OKI Print Job Accounting, OKI Configuration Tool, OKI Firmware Update Tool, OKI Front End Installer, OKI Maintenance Utility, OKI Network Card Setup, SENDYS Explorer Lite
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
54 dBA
42.7 cm
57.1 cm
27.9 cm
24 kg
Type: Printer
Brand: OKI
Price Range Ex VAT: 300 - 500
