OKI B731DN A4 Mono Laser Wireless Printer
Quicklinx: B167WS00 Mfr#: 01334101
  • Windows 8 (32/64 bits)
The B731dn printer from OKI is designed to enhance productivity in demanding environments. This digital monochrome printer can deliver powerful, cost-effective performance, providing crisp, clear documents with high speed and low levels of user intervention. They're a powerful, reliable solution for your work group printing needs.
  • Feature-rich and up to any task
    Perfect for high-volume applications, both printers have high monthly duty cycles. If your business requires lengthy proposals, reports, memos, spreadsheets, schedules, you name it - day after day after day - these are the printers for the job.
  • Print from a USB flash drive
    Simply insert a USB memory stick into the USB port conveniently located on the side of the printer. Print select file formats without the need for a PC. Just follow the directions on the LCD display, and you're on your way in seconds.
  • At home in your environment
    This printer is compatible with current Windows and Mac operating systems, and all are equipped with high-speed USB and 1 Gigabit Ethernet connectivity, so that everyone can take advantage of the productivity and cost savings.
OKI B731dnw - printer - B/W - LED
Printer Type
Workgroup printer - LED - B/W
27 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 1321 mm
Print Speed
Up to 52 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
800 MHz
RAM Installed (Max)
256 MB (768 MB)
Language Simulation
PCL 5E, PostScript 3, EPSON FX, IBM PPR, XPS
Barcodes
Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
Media Type
Envelopes, plain paper
Total Media Capacity
630 sheets
Media Handling
100-sheet multipurpose tray, 530-sheet input tray
Monthly Duty Cycle (max)
200000 pages
Recommended Monthly Volume
30000 pages
Print server
UNIX, Linux, Microsoft Windows XP SP2 or later, Apple MacOS X 10.4, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits) SP2, Apple MacOS X 10.5, Microsoft Windows Vista SP1, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits) SP2, Apple MacOS X Lion 10.7, Microsoft Windows Server 2008 (32/64-bits) SP1, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
Microsoft Certification
Compatible with Windows 7
3-year warranty with product registration
43.5 cm x 49.8 cm x 41 cm
Printer Type
Workgroup printer - LED - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
5 sec
Language Simulation
Fonts Included
87 x scalable PCL , 136 x PostScript , 1 x barcode
Barcodes
Media Handling
800 MHz
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
76 mm x 127 mm
216 mm x 1321 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
Media Weight
64 g/m² - 253 g/m²
630 sheets
Media Feeders
1 x automatic - 100 sheets - 216 x 1321 mm weight: 64 g/m² - 253 g/m² , 1 x automatic - 530 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m²
Max Media Capacity
3160 sheets
Output Trays Capacity
500 sheets
Duty Cycle
200000 pages
30000 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 3, IPP, HTTP, HTTPS
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, WEP, TLS, WPA, WPA2, IPsec, 802.1x, IP filtering, MAC address filtering
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 10000 pages ISO/IEC 19752
GS
Power supply - internal
Frequency Required
50/60 Hz
850 Watt
Power Consumption Stand by
95 Watt
Power Consumption Sleep
3.9 Watt
Software Included
OKI LPR, OKI PrintSuperVision.net, OKI Template Manager, OKI PDF Print Direct
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
57 dBA
Sound Emission (Quiet Mode)
53 dBA
43.5 cm
49.8 cm
41 cm
27 kg
