The B512dn black & white printer provides versatility, productivity and bottom-line savings for small workgroup environments.
If you're looking to improve the productivity and lower the operating costs of your business, the B512dn offers all of that and more.
For starters, the B512dn delivers up to 47 ppm, with the first page printing in as little as 4.5 seconds. It produces black & white output that's clear and crisp at up to 1200 x 1200 dpi resolution, using a two-piece consumables system for long-lasting performance and a low cost of operation.
The B512dn features a fast 667 MHz processor, as well as 3 GB of memory. It has a 630-sheet standard paper capacity (530-sheet main paper tray + 100-sheet multi-purpose tray) and can be outfitted with an optional 530-sheet 2nd paper tray, giving them a maximum capacity of 1,160 sheets - for longer uninterrupted productivity.
Fit for any work environment
With its compact size, the B512dn fits just about any work space. It has USB 2.0 and 1 GB Ethernet interfaces standard. The B512dn supports cloud/mobile solutions such as Google Cloud Print, AirPrint for Apple iOS and OKI Mobile Print app for Android devices. -
Cost-efficient LED printing
The B512dn employs LED printing technology pioneered by OKI over 20 years ago - and is still innovative today. OKI LED printheads have no moving parts, making them ultra-reliable. OKI printers are compact, environmentally friendly, energy efficient, and use significantly less raw materials in the manufacturing process. And they deliver HD (High Definition) printing for more accurate and striking documents. The B512dn comes with duplex (2-sided) printing standard, leading to fewer user interventions and savings on media costs. Its Deep Sleep mode - which reduces energy consumption to less than 1.5 watts - and Auto Power Off feature - which shuts off the printer after a long period of no activity - have earned the B512dn an ENERGY STAR rating.
- OKI B512dn - printer - B/W - LED
- Printer Type
- Workgroup printer - LED - B/W
- 13 kg
- Media Size Class
- A4/Legal
- Max Media Size
- 210 x 1321 mm
- Max Media Size (Custom)
- 210 mm x 1321 mm
- Print Speed
- Up to 45 ppm - B/W
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN
- Processor
- 667 MHz
- RAM Installed (Max)
- 512 MB
- Flash Memory Installed (Max)
- 3 GB
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, IBM ProPrinter, XPS, PDF 1.7
- Barcodes
- Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
- Total Media Capacity
- 630 sheets
- Media Handling
- 530-sheet input tray, 100-sheet bypass tray
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 750 - 5500 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple MacOS X 10.6.8, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition
- 3-year warranty with product registration
- 28.6 cm x 38.7 cm x 39.4 cm
- Printer Type
- Workgroup printer - LED - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- First Print Out Time B/W
- 4.5 sec
- Fonts Included
- 87 x PCL , 136 x PostScript , 2 x bitmapped , 1 x barcode
- Barcodes
- Media Handling
- Processor
- 667 MHz
RAM
- 512 MB
Flash Memory
- Flash Memory
- 3 GB
Media Handling
- Media Size Class
- A4/Legal
- Max Media Size
- 210 x 1321 mm
- 210 mm x 1321 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- 630 sheets
- Media Feeders
- 1 x automatic - 100 sheets weight: 60 g/m² - 163 g/m² , 1 x automatic - 530 sheets weight: 60 g/m² - 105 g/m²
- Max Media Capacity
- 1160 sheets
Duty Cycle
- 100000 pages
- 750 - 5500 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 3, IPP, HTTP, HTTPS, IPPS
- IPsec
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 630 Watt
- Power Consumption Stand by
- 80 Watt
- Power Consumption Sleep
- 1.4 Watt
- OS Required
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 56 dBA
- 28.6 cm
- 38.7 cm
- 39.4 cm
- 13 kg
