Your basket is empty
OCZ 480GB Vertex 460A SATA 6GB/s 2.5" Solid State Drive
Quicklinx: 9Z2MWS00 Mfr#: VTX460A-25SAT3-480G
OCZ introduces the Vertex 460A for those seeking a high-performance yet value-minded SSD. Combining OCZ's own controller design and superior flash, Vertex 460A keeps your system ahead of the game and delivers a faster, more responsive PC experience.
OCZ Vertex 460A - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
A19nm multi-level cell (MLC)
2.5" x 1/8H (in 3.5" carrier)
SATA 6Gb/s
Native Command Queuing (NCQ), shock resistant, TRIM support, OCZ Barefoot 3 M10 controller, S.M.A.R.T., 44/1K bit BCH ECC
69.75 mm x 99.7 mm x 7 mm
113 g
3 years warranty
480 GB
256-bit AES
2.5" x 1/8H
SATA 6Gb/s
69.75 mm
99.7 mm
7 mm
113 g
Performance
Internal Data Rate
545 MBps (read) / 525 MBps (write)
4KB Random Read
95000 IOPS
4KB Random Write
90000 IOPS
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H or 3.5" (with included bay adapter)
Power Consumption
3.45 Watt
Software Included
Acronis True Image HD
3.5-inch bay adapter
UL, VCCI, C-Tick, BSMI, FCC, KCC, WEEE
Limited warranty - 3 years
70 °C
